Catalytic converter
Discussion in 'Gen 2 Prius Technical Discussion' started by Cbakerjones76az, Aug 26, 2024.
  1. Cbakerjones76az
    Cbakerjones76az New Member
    Tempe,az
    I have a 2008 Prius hatchback and the check engine light is on for needing to replace the catalytic converter in bank 1. I can't afford to do the expensive route so therefore I have found a friend who is mechanically inclined and will replace it for me and I'm going to buy one off of eBay but I need to know how do I know I'm buying the right kind of catalytic converter considering there are two in the 2008 Prius. I don't know which one I am supposed to buy it is supposed to be for Bank One but how do I know the converter is for Bank One. If anybody knows please let me know I do not want to buy the wrong thing.
    Meg&Bear likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,516
    Durham NC
    You don't need to worry about all that bank business You have one catalytic converter and one exhaust pipe when you buy one online for a generation 2 there's only a couple options it'll look just like what you have but realize that the catalytic converters used in the Prius are high content or something along those lines so replacing with not the same usually doesn't get your light turned off and if you have to pass emissions in your state you will need to have a factory catalytic converter or one of two federal approved units I think the magnaflow and one other one may carry the EPA certification that may get you through your state not including California That's another ball of wax so I don't know what it is you need to make happen and where I'm in a non-emissions county in North Carolina I can have a pipe or nothing or can I open exhaust if I want in my '09 I have a pipe from the springs that connect to the exhaust manifold and the donut all the way back is just a pipe I believe that's right no converters nothing resonator was cut out all of that and if I put a spacer that I have and I just haven't gotten around to putting it in it may put the light out but where I live the light doesn't matter All I have to do is honk the horns put on the turn signals and show the lights work call the safety inspections $13.
  3. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    Your better off going to a good auto parts website to get the correct part number for your car.
    Online Toyota Parts Superstore | OEM Parts Online
    Then take that part number to do a parts search. You'll have a better chance of getting the correct part this way.
    Hope this helps...
  4. Tombukt2
    13,858
    2,516
    Durham NC
    This car is titled and registered in Arizona kind of like my county isn't it aren't you about allowed to do anything you want with your cars in Arizona this model shouldn't need an emissions test or anything so then you get rid of the catalytic converter leave the O2 sensor bung in place get a spacer for that and screw that O2 sensor into the spacer you screw in which should be a 90° bend with a piece of converter material in one end of it and that may put your light out for your PO420 code and you roll on for Jesus another 3-400,000 mi you're sitting at 160 or so now so if you don't have to do much don't gas mileage and all that is not affected by this The light is on because the parameter is set too tight they did this in my AE111 Corolla ACDelco did there was a firmware fixed but I don't think there's anything for the Prius they would rather sell you $3,500 converter installed and out the door It's a good look for them for 45 minutes.
  5. BiomedO1
    4,594
    2,410
    Left Coast
    I don't know what the EPA smog laws are in Arizona!! She asked how to find the correct part number for her car. That's the information I provided.
    It's between her and her mechanic if they just want to fool the sensor and knock out the catalyst honeycomb.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    #6 rjparker, Aug 27, 2024
  7. Tombukt2
    13,858
    2,516
    Durham NC
    I'm waiting for her to say whether she has emissions or not that's all then she doesn't have to do anything really unless she wants to
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    If the performance of the car has not changed, I wouldn't stress about getting it changed. I've had a 2005 that I purchased used, had the P0420 code, and I drove it for over a year, getting 50+mpg. Then got run off the road by an SUV that liked my lane better and the car got totalled. Just because there is a P0420 code, does not mean you HAVE to immediately get a new cat installed, but obviously, your situation may be different from mine.
    That being said, I have installed dozens of these since 2020 and have very good success. I've had ONE car start giving the P0420 code again about a month ago, 4+ years after installing. They are a very very good fit and easy to install. The tube is crimped down to 1.75 inches at the tip, which is an EXACT slip on fit to the Prius piping. Unfortunately, the kit comes with a 2" clamp, so I purchase a 1.75" clamp for $5 from Orielly auto and it seals the joint perfectly. This model catalytic converter is currently only about $75 on ebay. I have two of them sitting in the shop still in boxes in case of need.
    Catalytic Converter 2004-2006 2007 2008 2009 for Toyota Prius 1.5L Front | eBay
  9. ebikeman
    ebikeman Member
    121
    Northwest
    Thank you for this link. Over the years, people who buy the cheap $100 Cats usually get codes back in a few months or so. The more expensive ones don't. Now, you show us a $47 one that works?
    How does a super cheap one work good?
    Wonder if some of the ones you installed got codes back but since it was a few months later, they never came back to complain?
    I was going to get one but there "out of stock."
  10. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Walker cat last in a month
  11. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    Manufacturer of aftermarket hot end emissions products
    BM catalysts are by my empiricism quality products and easily reach euro4 (g2) as checked in Europe. It is the only non OEM I have validated that keeps Prius gen2 Efficiency Monitor Value below the dreaded threshold.
    #11 priumium, Dec 6, 2025
  12. Tombukt2
    13,858
    2,516
    Durham NC
    So how much do you pay for their cat for the generation 2 and what country are you in?
  13. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    As stated in the OPs profile, Sweden.
    priumium likes this.
  14. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    Yes, and since UK left EU it’s likely the same price over here as in the states I would assume, part from shipping which can be a birch…
    I managed to get one eu4 on sale for apx 450euro.
    I also at the roughly same time bought a 300euro from ECC (also uk) for a friends gen2 2008 stolen.
    This ECC one did not pass the Toyota Prius 2 very demanding monitor algoritm, as the BM did.
    So I had to add a spacer with a tad of rockwool to the ECC O2 to make the emission monitor happy (it’s mainly big fluctuations in the O2 sensor that this monitor algorithm hates)…
    in Sweden all exhaust is tested at inspection. Data showed it was very good values with the ECC that even passed eur5 limits…
    #14 priumium, Dec 7, 2025
  15. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    Here is a summary of the g2 algorithm data…
  16. ebikeman
    ebikeman Member
    121
    Northwest
    The spacer was mentioned so I bought one. I got a really good one with a cat built in, angled real heavy duty. Weighed a few pounds.
    I misunderstood. I thought that fixed it. It keeps the light off but I only get about 30mpg. Since the O2 doesn't get any reading, it runs lean, the car has to richen up the mixture so it puts more fuel in. Now I'm running very rich so I get low gas millage.
    ebm
  17. dolj
    dolj Senior Member
    8,645
    4,395
    Yeah, those spacers don't fix anything. They just hide the problem from ECM, so it can't do its job properly.
  18. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    The spacers themselves do not fix anything alone, it’s logical. But, they add the space to add very little rockwool - and now the ECM is happy/fooled for many km.
    Oh, and the exhaust values are well within EU4 specs, according to Swedish inspection analysis.
    #18 priumium, Dec 8, 2025
  19. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    Oh my, this style will not make the Prius ECU happy/fooled ever, atleast that is what I have heard. I have never tried one so please link product.
    Do you have a scan log to show O2/AfR and fuel trim data etc?
    My empiricism have forced me to read up a lot about the Toyota algorithm for emissions.
