Catalytic Converter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MelissaAnne, Jan 29, 2011.
  1. MelissaAnne
    MelissaAnne New Member
    265
    52
    Louisiana
    Wow, I have never had to question my intelligence this much in my life. Usually I'm the smart one that knows everything. haha
    Well, I hope doing all this is still more cost effective than going to a Toyota dealer.
    I'm just so confused. I hope my boyfriend has an idea on what to do. I'm going to have to email all this to my father and see what he says. Maybe he can explain it in "Melissa Form" so I can grasp the concept a little better. Too bad none of you live anywhere near me to give me a hand. :(
  2. Patrick Wong
    18,210
    6,526
    I'll try to summarize the thinking here:
    1. You said that your car has 230K miles and suffers from poor powertrain responsiveness. The check engine light comes on from time to time and you've been told that the catalytic converter needs to be replaced. I assume that the catalytic converter DTC, P0420, was logged. (Please check the repair invoice that documents this diagnosis, to confirm whether this DTC is listed.)
    2. When you notice lack of engine performance, the first question to ask is whether the engine needs to be tuned-up. Who knows whether the prior owner kept up with the 100K and 120K mile services which should have been performed 2x by now. Therefore I suggest that you replace the iridium spark plugs, engine air filter, and the air/fuel ratio sensor; and clean the mass air flow sensor, throttle body interior and throttle plate.
    3. If you find that the engine performance is improved after this tune up, you may also find that the catalytic converter DTC will no longer be logged. If the engine is performing more efficiently then there's less unburnt hydrocarbon gases in the exhaust for the catalytic converter to deal with. Therefore, even though the catalytic converter is marginal, it may be "good enough" if the engine is running better.
    4. After you've restored engine performance and have taken care of the catalytic converter issue, then you can focus on other maintenance like 5K mile engine oil and oil filter changes, replacing the engine coolant and transaxle ATF fluid, replacing the PCV valve and serpentine drive belt, inspecting the engine coolant pump for leaks and replacing if needed, checking the suspension and brakes, etc. There is a good chance that the front struts and rear shocks are bad, and the front brake pads and rotors and rear brake shoes probably have to be replaced. Also check with your Toyota dealer for service campaigns that are outstanding on your car. For example you can get a replacement inverter coolant pump (and inverter coolant) free of charge under a limited service campaign currently underway.
    5. You'll have to spend quite a lot of money on the suggested maintenance in #2 and #4, but if you can take advantage of free labor then you're still much better off than if you go to the dealer. Considering that your car has logged so many miles, this maintenance needs to be done if you want to drive a reliable vehicle.
    I hope this recap helps.
  3. MelissaAnne
    265
    52
    Louisiana
    I have to find the invoice. I thought I grabbed it before I moved across the country but I can't seem to find it. I've noticed the check engine light comes on with certain gasoline types. An example is yesterday, there were no Chevrons around so I used a Valero, only filled up with 2 gallons until I could get to a Chevron. The check engine light is on now, it'll most likely turn off once my car burns the Valero gas and gets to the Chevron.
    Before I bought the car the dealership gave me a 6 page summary of all the work done on the car. It was very well maintained because the previous owner drove it to San Francisco daily which was about 300 miles round trip.
    Can I get a majority of these things (spark plugs, engine air filter) at an auto parts store?
    I appreciate all your help in this. It has been so stressful.
  4. Patrick Wong
    18,210
    6,526
    Take a look at the six-page summary to see the last time the spark plugs, air filter etc were serviced. You might be able to take some of my suggested items off the list if this work was done recently.
    The fact that the check engine light goes off and on indicates that the catalytic converter is marginal (but not totally dead). If the air/fuel ratio sensor is replaced, that might improve your engine's performance and keep the CEL light off for a while.
    You will probably not be able to get the iridium spark plugs at your typical discount auto parts store as these are special. I recommend you consult with your BF to decide what work he can do for you, then order everything you need at Champion Toyota, Houston: toyotaworld.com
    They offer ~25% discount from MSRP for web orders and the ground shipping time to your Louisiana location should be very fast. Good luck.
  5. MelissaAnne
    265
    52
    Louisiana
    Well this is a slow process because every time my boyfriend comes home from work its: shower, dinner, xbox, sleep. Hard trying to talk to him about it. I found the spark plugs at an auto parts store here for $6.99 each, $4.99 after mail in rebate. They're Autolight Iridium Spark Plugs. Those I am buying later today along with an air filter since I can get these at the store. My mother is still looking in California for my diagnostic test results. If she doesn't find it by the end of today I'm going to call the dealership and ask if they have it saved in their computer so I can give you the exact code.
    The check engine light went off two days ago just like I knew it would as soon as it burned through the Valero gasoline.
    Pretty much, this is going to end up being a "One thing at a time" fix. If I were in California at home my father would've fixed it by now. Maybe I can talk my parents in to sending me some money for some of the stuff. :(
  6. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    Melissa Anne, I think the first step to repairing your car is to unplug the Xbox.
  7. sitruc
    sitruc Junior Member
    22
    united states
    Haha, was thinking the same thing. We must be "old school", like her dad, because taking care of my lady's needs, comes before video entertainment.
  8. MelissaAnne
    265
    52
    Louisiana
    I've tried, numerous times. It's quite sad actually but oh well. He does work 7 days a week, 12 hours a day.
    lol
  9. Ryanpl
    780
    158
    Brooklyn, NY
    You can always with hold _ _ _.
  10. MelissaAnne
    265
    52
    Louisiana
    AGAIN, unfortunately doesn't do anything. I'm pretty sure I'm here to cook, clean, do his laundry, color coordinate his work bandannas, and get up at 4:45am to make the best lunches ever. But, sometimes I get his bank card, which will buy me some spark plugs today. So, I can't complain that much. Well, actually I can. haha
  11. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    As a working man, I appreciate the days your boyfriend endures. As a mechanic, I also know how important it is to maintain your vehicle. Patrick Wong is correct with his recommendations. So with caution I make this suggestion, and appologize ahead of time if I speak out of place.
    Have Toyota give you a full estimate of the work needed on paper. All of it. In your own way sumit this to your boyfriend. His being a pipefitter means he can turn a wrench. You might be suprised how dollar figures and a good woman can motivate even the most fatigued man.
  12. Patrick Wong
    18,210
    6,526
    I would caution you about using Autolite plugs or any other than the correct NGK or Denso iridium spark plugs as specified in your owner's manual, as the service life will be shorter. You might try an auto parts store that specializes in import auto parts, to see if they sell the correct plugs.
    Also, if your BF is not successful in repairing your car to your liking, and you go back to the Toyota dealer for help, one of the first things the dealer tech will do is to identify and replace any non-Toyota parts that are potentially relevant to the problem. The spark plugs fit into that category. Hence, you'll get to pay for those parts 2x which is not a cost-effective move.
    It's OK that your repair will be performed one thing at a time. It sounds like your BF is logging many hours - good for him, and that beats the potential alternative of being unemployed by a considerable amount. If he gets more relaxation out of playing with the Xbox than working on your car, I can't fault that.
  13. Ryanpl
    780
    158
    Brooklyn, NY
    Melissa Another option for spark plugs is the NGK (4996) IFR5T11 Laser Iridium Spark Plug. Amazon.com sells them for $7.73 a piece. I believe these are OEM quality [ame="http://www.amazon.com/NGK-IFR5T11-Laser-Iridium-Spark/dp/B001B0Z0B2/ref=wl_it_dp_o?ie=UTF8&coliid=I3LXNQ97PL9L2H&colid=4M9TQ7QWA7JA"]Amazon.com: NGK (4996) IFR5T11 Laser Iridium Spark Plug, Pack of 1: Automotive[/ame]
  14. Patrick Wong
    18,210
    6,526
  15. MelissaAnne
    265
    52
    Louisiana
  16. MelissaAnne
    265
    52
    Louisiana
    Ok. I wasn't sure about spark plug brands. I figured if it was iridium then I was good. So I'm gonna go with the ones suggested above by Ryanpl.
    Other than those, is there a specific engine air filter I should get as opposed to a general one that says it will "fit" my car?
  17. Ryanpl
    780
    158
    Brooklyn, NY
    You will need to buy 8 of these spark plugs. Four you keep and four you can ship to me as a finders fee :D. Or you buy 4 and tell me to stuff it.
  18. MelissaAnne
    265
    52
    Louisiana
    HAHAHAHA I like your style. I'm not mean enough to tell you to stuff it unless I'm referring to a Thanksgiving turkey. If I had the money to buy so many I would've sent you some. My mother taught me the skills of sucking up and buying friends as I grew up. You'd be surprised how much it costs to ship home made cookies to random people around the United States these days. $20... Yea, I've done it. I'm a people pleaser though, what can I say?!
  19. Ryanpl
    780
    158
    Brooklyn, NY
    I prefer Toyota air filters, although you'll get all sorts of advice about what to buy. If you haven't changed your cabin filter change that one as well.
  20. MelissaAnne
    265
    52
    Louisiana
