Catalytic convertor shield
Discussion in 'Prime Main Forum (2017-2022)' started by IABoy987, Oct 2, 2022.
  1. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Saw news stories of thieves stealing these under cars in less than 2 minutes, and foiled if there is a steel plate bolted/welded over convertor. Has anyone had these installed in their Prius? My dealer is trying to get one but unsure of delivery time.
    Would run of mill muffler shop have same shield they can install, or are there special things Toyota has to do so Prius engine and electronics are not ruined?
  2. Mendel Leisk
    42,343
    Lots of threads here on the subject. The shields are “fairly” effective, albeit maybe in part because while not completely secure, they they’re enough of a deterrent that the thieves move on. Cap City Muffler is one maker; there are several.
    IABoy987 likes this.
  3. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    I purchased a cat shield unfortunately through the Toyota dealer which up charged me for it. The one on their website is the one that I had placed on my car for a 2020 Prius prime. The local car repair shop put it on for $79. Toyota wanted more than $300 in labor.
    it’s pretty secure with their proprietary bolts. I’m sure if someone had the time they could cut through it but as someone has pointed out on here it provides deterrence. If you want to quickly steal a catalytic converter and move onto the next vehicle they would probably pass on my car.
    ccna101 and IABoy987 like this.
  4. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Buy the MillerCat Stainless Steel cat shield. That's also likely what any Toyota dealer will install.
    304 Stainless Steel is much "stronger and harder" than aluminum. Stainless Steel is also a bigger PITA to cut through, or drill through.
    Stainless Steel will last for the lifetime of your car. Aluminum starts to pit immediately (important for snow/rain areas).
    Any cat shield is mainly a deterrent.
    If the person has 10mins, and can make as much noise as they want, like 2am in an over-night commuter lot, then there's just about nothing that will stop them.
    Also, any targeted theft (the thief is targettng your car), means that the thief could also bring any special bits/tools/sockets needed to get to your cat. Yes, especially in Calf, there are often repeat thefts, on the same vehicle.
    Otherwise, having that full-length PITA 304 Stainless Steel cat shield, is going to be one of the best deterrents.
    You may want to also consider getting a professional alarm (~$1000+) with an electronic tilt sensor installed.
    After the car is turned off (and the alarm is active), there's no reason for the car to "magically on it's on, tilt 1+ degrees". :)
    You can see with an ~$20 digital angle gauge (Amazon :)), how the angle of the car changes, as you jack the car up.
    There's no magic to a good alarm tilt sensor. Just software to distinguish between a gust of wind, and the car being jacked up.
    Good Luck!
  5. Scott Caputo
    Scott Caputo Junior Member
    39
    Los Angeles
    Mine just got stolen and I had a shield on there. It didn’t slow them down at all. They just went farther up into the gap between the cross frame and the engine/trans and with a long sawzall blade they were able to cut through the exhaust in the curved section and then they just cut it farther away on the back end and off they went. It was parked in my driveway So, I’d say that if you have a shield or are thinking of getting one maybe figure out how to augment it or go with a different option.
  6. Trollbait
    12,825
    Ecomodders have used window screening for belly pans. Secure the metal version well enough to keep it from being easy to rip off. Cutting through it with a sawsall isn't fun.
    An extreme strategy is to install and air suspension that lets you drop the car down so a jack can't be used.
  7. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    mount this along the frame to ... protect the bugs and dirt from entering the car :)
  8. wirelessjava
    wirelessjava Member
    105
    23
    Union City, CA
    Was this a miller cat shield or the cheap China stuff out there on Ebay?
  9. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    I was standing near a Tesla and the car said it’s recording me. Didn’t touch it just parking my own car. Unless I was dreaming but I know I wasn’t. How about something like that? You are being recorded and it’s all on our office computer now. Smile.
  10. sylvaing
    sylvaing Senior Member
    1,221
    517
    Sentry mode was On, which is common for Teslas parked in a public space (I do too). In that mode, it's always recording but when it detects movement close to the vehicle, it saves that recording so it can be viewed later on. Since the latest update (2023.26.x), if you pull the handle without a recognized phone key (your phone is the key), it will also save that recording.
    The recording is stored locally on a USB stick in the (locked) gloves compartment. There is an open-source project that converts a Raspberry Pi to a "USB stick" and sends the video to your home NAS through WiFi so you don't need to bother taking it off to save that recording somewhere else.
    Louis19 likes this.
