Catalytic got stolen but now my car smells of burnt oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Miguel Olivares, May 30, 2023.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    hey all. my cat got stolen, was replaced with an aftermarket.
    i noticed when i went underneath the hood there were some hoses that were cut.
    now, whenever i drive on the highway, or turn on ac, i get these really bad smell of burnt oil fumes. everytime i drive my car for at least an hour, i wake up with a. headache the following day.
    i will try to upload a video to show the hoses that were cut
    if you notice on the right side, there are two hoses that were cut
    what do y’all think is happening?
  2. PriusCamper
    PriusCamper Senior Member
    11,059
    4,502
    Pacific Northwest, USA
    I'm not aware of any hoses that would be that close to heat shield over the exhaust header... I think the problem you're having is the person who replaced with aftermarket had a shorter replacement cat than needed and its causing your flange gasket to leak where cat connects with the exhaust header. This usually means a slightly different sounding engine and the engine compartment will smell like a 1970's car that does not have a catalytic converter. If that's the source of the problem take it back and make them fix it because they failed on the first attempt.
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Do you still have the 2008 gen2 listed in your profile?
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    The hose I see looks like the a/c drain. AKA: normal.
    PriusCamper likes this.
