Catastrophic failure, no brakes at 50 MPH
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by skanex, Jul 16, 2014.
  1. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    The emergency brake supply can also run the accumulator pump a bit, not just the valves. It was removed in GenIII, so apparently not a compelling advantage to keep it.
  2. skanex
    skanex New Member
    Hi all,
    So just to update, the issue was apparently a short in the 12v Aux battery and hey reviewed OP history and freeze frame data. The battery passed GR-8 but failed Under load. They replaced the battery and it seems to be running okay and I just have to wait to be reimbursed. Also apparently I was wrong: they did replace the pump when I was in for an oil change back in January. Based on your experience...does this seem like I'll be fine from here on out?
    Toyota corp said that if anything else happens they'll replace the DC Inverter free of charge as it's a part of the hybrid drive.
    ftl likes this.
    51,948
    i think your good and i would get that in writing.
  4. Former Member 68813
    3,524
    983
    US
    #24 Former Member 68813, Aug 1, 2014
    edthefox5 likes this.
  5. fuzzy1
    10,454
    If 112 pounds (500 newtons) of brake pedal force was applied, and the underlying manual hydraulic brakes still did not work, then it is prima facie evidence of failure to meet federal passenger car braking regulations. It very much should be reported.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    If a dead 12 volt battery caused these issues the Prius would quickly become a pariah.
    Dead 12 volt batteries is what built this forum. Biggest thread maker here.
    And why is Toyota reimbursing you for anything?
  7. fuzzy1
    10,454
    If a simple dead 12V battery caused the brake system to fail completely, so even the underlying manual hydraulic system (without power boost) didn't work when the driver applied full body weight, then the design would flunk federal passenger car regulations. A recall would be mandated.
    There have been hints of possible problems in past threads, but not enough reports to form a critical mass to distinguish actual problems from operator errors.
  8. bisco
    51,948
    between u/a and no brakes, it's amazing they sell any.:rolleyes:
  9. taylor_priusII
    taylor_priusII New Member
    17
    Morton, IL
    It's official: these cars are death traps.
  10. fuzzy1
    10,454
    Motor vehicles in general are death traps.
    The Prius is no worse than normal. In fact, with its IIHS Top Safety Pick rating, it is better than average.
    uart likes this.
  11. orenji
    orenji Senior Member
    5,887
    3,488
    Using any machine that propels you has a risk of death, so its not fair to say that Prii are death traps. I am sure many on this site who have been in an accident would say otherwise.
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    See this thread, for example:
    New Prius C Crash | PriusChat
  13. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Maybe Toyota US should use the softer brake discs and pads we have over here. Sure they don't last as long but they do work very well (even without regen).
    What do you want? Brakes that really bite and last 60,000 miles or brakes that are hard but last well over 100,000? I know which I'm happy with :)
  14. csoppe
    csoppe New Member
    I had the same issue happen on three occasions to my car (2004 Prius, about 114K miles on the car)! The last time it happened was on Monday, August 18, 2014. My car is in the shop right now and Toyota is scratching their heads after they thought they had fixed the issue on two other occasions (May 2014 and January 2013). Luckily no one was killed or hurt.
    Please shoot me an email at carol . soppe at gmail . com. I'd like to get your Toyota case number as Toyota is telling me that they haven't run into this problem with any other vehicle. Like you, I do not feel safe driving the car ever again and if this is part of a larger problem, they need to address it. Thanks!
  15. csoppe
    csoppe New Member
    Hi. Do you have a Toyota case number for when it happened to you? I've had this happen to me on three occasions over the last two years. They replaced the a computer chip the first time around (about $3K) and then checked all the wiring (they found rust on one of the wires and thought that was an issue). The third time just happened this week and Toyota is scratching their heads as if they have never seen this before.
    Of note, I did have the 12 volt battery replaced between the 2nd and 3rd time it happened. Be safe in your car! Based on my experience, I think it could happen again.
  16. fuzzy1
    10,454
    ^^ Did you put your full body weight into the brake pedal, or at least 112 pounds (500 newtons metric?) If so, and the brakes still didn't work like old fashioned manual (no power assist) brakes, then this would be evidence of failure to meet federal passenger car braking requirements. Proven failure would force a recall.
    But even at lower pedal forces, it could point to a potential serious problem.
    Any evidence pointing to such problems needs to be documented here:
    NHTSA: File a Vehicle Safety Complaint
  17. bisco
    51,948
    what if you only weigh 111?
    orenji likes this.
  18. fuzzy1
    10,454
    Most people can brace against the seat well enough to press with considerably more force than their body weight.
  19. orenji
    5,887
    3,488
    Fat is good!
    milkman44 likes this.
  20. bisco
    51,948
    fat, is where it's at.
