CatShield vs. CatSecurity catalytic shield
Discussion in 'Gen 2 Prius Main Forum' started by myscreennameis, Jul 11, 2021.
  1. myscreennameis
    myscreennameis New Member
    Torrance, California, United States
    Four Touring
    Catalytic Convertor Shield.
    I'm located in Southern California, and am interested in knowing out of these two companies: CatShield by MillerCAT, at, and CatSecurity at getcatsecurity, which company is the preferred company to go with and why, (what it is about their product that made them choose it over the competition).
    I'm having a hard time deciding between CatShield by MillerCAT and CatSecurity by getcatsecurity. I'm getting conflicting info. One owner claimed that the downside to CatSecurity, is that it screws into the frame of your car, where another user says that this is an upside because it fully incorporates with the chassis and the, "existing main shield." (By the way, what is the "existing main shield"?) Why would installing into the frame of the car be a downside? Both claim theirs is corrosion resistant, MillerCAT charges an extra $30 for the "best" security hardware, whereas the security screws come with the CatSecurity unit. MillerCAT offers either an Aluminum Shield for $180, or a Stainless Steel Shield for $310, $340 if you order "the best," security screw kit, whereas CatSecurity shield offers only one unit, 30% off, at $249, made out of a combo of Aluminum & Stainless Shield.
    I have heard both do cause temperatures to rise under the car, but, it is as can be expected, and should not raise any concerns. I can only assume that the aluminum shield by MillerCAT & the Aluminum/Stainless Steel shield CatSecurity units would cause the least amount of heat build up. Both are similar in design, they both offer strategically placed ventilation and ability to get a smog check without having to remove the shield. It seems that CatShield is a more temporary solution, as MillerCAT states that the unit is, "fully removable," whereas, getcatsecurity makes no such claims of removability. Why would I want it removable? Isn't that the entire point of it, to protect the Cat? What good is its ability to protect my Cat from being stolen if it is, "fully removable."?
    Has anyone had any issues with rattling? Or any issues at all?
    Also, what is the typical cost to have it installed? For the CatSecurity Level 2 Kit unit, the local Toyota Dealership wants to charge me $169 - $250 for just labor if I buy it and bring it in myself, as they can't order it for me, or, for the CatShield, $450 for both parts & labor, and only
    A local muffler shop quoted me at $150 for labor to install the CatSecurity Level 2 Kit & offered to order it for me. Lastly, are both companies affiliated with Toyota ?
    Thanks in advance.
  2. caliwaves
    caliwaves Member
    65
    33
    TX
    I have the MillerCat installed on my two Prii (Gen II)
    No
    I've had it installed (parts+labor) at Dave Frost Auto in LA (authorized MillerCat installer) for $300 total. He gets the part for $150 each as he buys it in bulk, and installs it for $150. I have seen the install price range quite widely. I recommend comparing prices of authorized installers.
    MillerCat is an authorized toyota aftermarket part. I dont know what that means other than, Toyota has green lighted this product to be carried and installed at their dealerships.
    Hope this is helpful.
  3. Formula_Ron
    Formula_Ron Junior Member
    MN
    I bought the Cat Security shield and had it installed in Spring. I also bought stainless steel rivets (to replace the aluminum ones that came with it) and rubber-backed washers. I think I was charged $150 for labor. So far no rattles.
  4. PriusCamper
    PriusCamper Senior Member
    13,055
    5,305
    Pacific Northwest, USA
    There's loads of companies selling these right now because they are super cheap to make... And keep in mind they're a deterrent, so quality is not that relevent because all of them can be cut through or pried off with a pry bar. Just buy the cheapest $100 one you can find and get a friend who has floor jack and jack stands to install for a 12pack of cheap beer and a pizza! Only takes a half-hour.
  5. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    I see you're in California, I would add be careful of smog checks also. Make sure the shield (which ever you choose) can see through the "holes". Smog requires the tester to "see" the cat. Each smog station is different of course, one station may let you pass and others may hassle you to remove it (or charge you to remove it).
  6. PriusCamper
    13,055
    5,305
    Yet another reason for installing your own cat shield... That way you'll be comfortable with removing it. As in cheap & easy to remove next time you have a smog check... A crow bar and a 10mm socket on a cordless ratchet can have that shield off in 5 minutes or less if you practice. :)
    #6 PriusCamper, Jul 13, 2021
  7. Fivel
    Fivel Junior Member
    New York City
    Seconding the advice to find a cheap one and install yourself — they really are only a deterrent, like bicycle locks, if the thief wants to get it off, they can, pretty easily, no matter how much you pay for it. I found one on ebay for ~$100. It took me about an hour to install, but I took my time, it was pretty straightforward, as long as you have a drill (and jackstands of course). Most will want you to install using rivets, but then you have to buy a rivet gun, and taking it off (if you ever need to do that) would be a hassle. I used self-drilling metal-to-metal screws (to avoid rattle, install using bonded washers like these). For added "security," you can epoxy some rivet heads on to make it look like they are riveted on, like this person did. All in the name of good fun!
    donbright and PriusCamper like this.
  8. PriusCamper
    13,055
    5,305
    I remember in elementary school when I realized all the cheap bike locks kids used on their bikes would snap just by pulling the bike out of the bike rack as hard as you could. I did NOT start stealing bikes, but my view of the world was shook and I was confused as to why no one got their bikes stolen very often?
  9. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    Miller probably says its replaceable because if you check out their installation guide (link below), their shield is made so that you attach rivet-nuts to your car undercarriage, in holes that are already in the undercarriage, and then you hold up the shield and screw it to the rivet-nuts. But they claim the screws have proprietary heads that makes them difficult to remove without the proprietary tool. if you did want to remove it, just get your tool out and remove the screws.
    https://cdn.shopify.com/s/files/1/0447/4758/7749/files/Stainless_Steel_Prius_Gen_2_Installation_Guide.pdf?v=1625241470
    Which level of screws are right for me?– MillerCAT Corp
    Compare this with the other shield products where you basically have to drill a bunch of new holes into your undercarriage and then you are supposed to rivet the shield directly to those holes you just drilled. If you want to remove it, you will have to get a tool to remove those rivets, like grind their heads off or whatever. Alot more hassle and mess than unscrewing security screws with your security screw driver.
    I tend to agree with everyone else, the best shield is one you actually put on the car as soon as possible. The differences are not that much. A true thief will get through rivets or through security screws if they are determined enough. You can see threads on this board where they just took a sawzall or something and cut right through the shield itself - so the screws vs rivets debate in that case was completely irrelevant.
    The shield is a deterrence mechanism more than anything. Thieves are calculating risk v reward in their head and that shield makes the risk go way way up because it slows them down, and it makes their job a lot noisier. The thieves that attacked my car apparently were slowed down enough or deterred enough so they only cut the pipe, didn't finish the job by attacking the shield itself, and ran off. If i didn't have the shield, they could have taken the cat in a few seconds.
    Oh, as to the temperature... you can actually read both your Cat temperatures using an OBDII scan tool and an app like Torque Pro. I haven't noticed any significant difference in mine after the shield install. Spikes to 1300 then down to 1000 degrees F like normal (summertime)
    #9 donbright, Jul 16, 2021
  10. PriusCamper
    13,055
    5,305
    A crow bar between the shield and the underside of the car can bust through any kind of fastener you use very quickly...
  11. myscreennameis
    Four Touring
    I understand that it's just more than a deterrent. That being said I want to choose the best deterrent; the one that will make it harder for the thief to steal my catalytic convertor.
    Would installing into the frame of the car vs the plastic splashshield make it more difficult to remove? I'd assume so.
    Would Stainless steel vs aluminum be harder to cut through/pry off? I'd assume so.
    If it would be a better deterrent to get a unit that installs directly into the car frame, than I would go with that unit despite it not being Stainless steel. However, if it makes no difference in whether it's installed into the frame or the splashguard, then I will go with the Stainless steel unit by MillerCAT.
    My Prius is disabled and awaiting parts to arrive, so, I want to make the best decision, not a rushed one.
    Thanks again everyone.
  12. myscreennameis
    Four Touring
    *That it's just a deterrent.
  13. The Lizard King
    89
    56
    I got the CCM shield for $160 shipped. I used all the rivets and screws that came with it on the installation. No rattles. No more stolen catalytic converter (so far).
    Sanchan likes this.
  14. donbright
    241
    151
    33
    oklahoma
    to be clear all the commercial ones i have seen connect directly to the frame / body , i have never seen one attach to the plastic.
  15. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,498
    Taylors, SC
    view from front.JPG It really doesn't matter which one you get. Int's important to get one.
    All those marketing claims like stainless steel and special security screws appeal to the purchaser, not an effective enhanced deterrent for the thief. Any battery powered angel grinder will make quick work at removing these fasteners.
    Cheap additional deterrent includes painting the car and most of the exhaust with VHT header paint like this and placing catalytic "converter engraved stickers" so they are readily seen by potential thieves,
  16. rogerthat
    rogerthat Active Member
    408
    125
    Georgia
    What's the point of the "catalytic converter engraved" sticker? I would think that thieves could just cut out the valuable part if the car's vin# was engraved in the body of the cat? I'm about to replace my cat and like the idea of that header paint as a deterrent - maybe spray on "after market cat" directly on the body so I don't get some idiot thief thinking it's a valuable one.
  17. Georgina Rudkus
    3,513
    2,498
    Taylors, SC
    The point of the "catalytic converter engraved" sticker is the same as the video or burglar alarm sign. It is an extremely cheap theft deterrent.
  18. rogerthat
    408
    125
    Georgia
    I'm just curious, how will engraving on the cat (or just stating that it is engraved) deter theft? Is it possible to easily cut out the valuable part of the cat therefore rendering the engraving useless?
  19. Isaac Zachary
    Isaac Zachary Senior Member
    2,671
    1,381
    Make lots of engravings all over it? Then make a stencil and high temp paint them all?
  20. rogerthat
    408
    125
    Georgia
    I get the impression that the only thing that will deter these thieves is if they realize that the Cat is an aftermarket one with a scrap value near zero. The bright paint might help point this out and/or a sticker or spray paint that states "aftermarket cat installed". I highly doubt these thieves are selling the cats on Ebay or as replacement parts - they're almost definitely just going to scrap the valuable sections. Wouldn't surprise me if some of the scrap dealers have a pretty good idea that they're buying stolen goods.
