Catstrap Catalytic Anti-Theft Help Needed for Installation
Discussion in 'Gen 2 Prius Main Forum' started by wpaxt, Aug 6, 2019.
  1. wpaxt
    wpaxt Junior Member
    Hi everyone. My 2005 Prius had its catalytic converter stolen in Eagle Rock recently. I've since had it replaced but have been warned that my car has now been marked by the thieves and it will happen again if I don't get some sort of protection. I want to get a Catstrap but am unable to install it myself. Can anyone recommend a shop in the Los Angeles area that could do this for me? I'm told by the manufacturer that there is a shop that does in this in Culver City but I have been unable to find the shop in my internet searches.
    Thanks for the help.
    Bill
  2. Calimobber
    Calimobber Member
    94
    82
    Death Valley
    Do you part on the street or in a driveway ? can you get put a camera on the car? Id think they would avoid your car since your already on high alert.
    Sorry no help on the install.
  3. AzusaPrius
    AzusaPrius Senior Member
    1,900
    826
    I just got everyone a nice discount of 5% at CatStrap.net
    Just enter discount code azusa.
    I have my eye on the CatEye alarm system.
  4. OC63RAG
    OC63RAG Member
    94
    42
    Check Craigslist, FB Marketplace and Offerup. Many shops advertise on those for cat shields. There should be someone close by that can do it.
    greengoblin68 likes this.
  5. alftoy
    alftoy Senior Member
    1,132
    510
    Saskatchewan, Canada
    #5 alftoy, Nov 3, 2021
  6. burrito
    burrito Active Member
    274
    114
    There's at least 1 picture posted on PriusChat of a catstrap which had been cut. I recommend the cat shield (or a knockoff).
    I don't know anyone in Los Angeles, but if you're calling around for prices remember to also check with tire places and muffler places.
  7. alftoy
    1,132
    510
    Cat Alarm for $179? Siren itself is $15
    Get alarm with remote for $30 Amazon, good reviews. Ideal may be better for under vehicle, water resistant?
    Motion Alarm.jpg Motion Cat Alarm.jpg Motion Cateye.jpg Motion remote alarm.jpg
    #7 alftoy, Nov 8, 2021
  8. DavidTB
    DavidTB New Member
    Virginia
    The vast majority of vehicles simply don’t have enough ground clearance to position the cutting tool to begin cutting the exhaust pipe from the opposite side of the catstrap. In the event this was possible, the thief would not only have the adhesive bond to contend with (which would be near impossible to pry off considering the limited amount of space under the vehicle), but also the muffler exhaust clamps that are used to clamp the strap on either side of the converter. This would force the thief to cut through the strap to remove the converter.
  9. alftoy
    1,132
    510
    Make your own cable strap or shield. Lots of ideas for cheap. Same amount of work to install Catstrap.
