Caution: The transmission lock mechanism is abnormal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Highspeed, Jun 29, 2008.
  1. whoda_thunk_it
    whoda_thunk_it New Member
    24
    Milwaukee - Riverwest
    When does this screen display?
    Over the last few weeks I have had something pop up on the MFD and beep, but it changes back so quickly that only the most recent time was I able to see the words "Caution" and "transmission" before it vanished.
    It has happened at highway speed an hour into the drive, at <20mph 1 minute after I started the car in the morning, and while demonstrating EV mode to a friend. There seems to be no comonality that I have found.
    Or do you think that I am getting a different caution statement?
    thanks
    Jeff
  2. whoda_thunk_it
    24
    It happened again on the way home from work last night! This time while sitting at a stop light facing uphill. Other instances noted in previous post.
    It comes and goes so quickly that when I notice the change and turn to look, the screen is changing back and I only see it for a fraction of a second. Is this something I should be seeing the dealer about immediately? I only have 2300 miles on it so far.
    Is there a list anywhere of all the possible warning messages that could be displayed?
  3. richard schumacher
    7,683
    1,066
    United States
    Mmm, I don't know about immediately, but unless you have access to Toyota's proprietary scan machine I'd say that a visit to a dealer for diagnosis is in your future.
  4. Patrick Wong
    18,210
    6,517
    You'll probably need to wait until you have a warning light come on and stay on. Otherwise it is likely that your dealer tech will diagnose no-trouble-found and charge you for one hour of labor time.
  5. Highspeed
    Highspeed Junior Member
    16
    PNW
    Just a quick update... It's been a long time and this problem continues. It only happens on hot days (yes I live in Vegas). All winter long - no problems. First day of 100*F it does it again. I replaced the battery last summer and that seemed to fix it for a few weeks but in the end I'm not sure it fixed anything. I took it to the dealer but the warning lights had gone off. They pulled two codes, one related to low voltage and one related to a solenoid in the transmission. This is an ongoing problem and I will post up with updates just in case others have this problem.
    PS - I now roll with the Optima battery and a solar trickle charge plugged into the lighter.
    Cheers
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Your solar trickle charger to the lighter isn't doing anything for you unless you've modified the lighter/powerpoint to be active while the car is turned off.
    Power Outlet Mod
  7. Patrick Wong
    18,210
    6,517
    What were the two DTC?
    Given the existence of the DTC, did the dealer tech recommend taking any action; or does the tech want you to wait until the problem gets worse?
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    To rule out a bad ground, I would back off then snug up the bolt that holds the ground wire connection to the unitbody, at the 12 vdc battery
    What exact DTC were reported?
  9. Highspeed
    16
    PNW
    I'm looking at my invoice from the dealer, he said the codes were the first things listed so...
    70150 DTC C2300 C2318 ACT
    These codes were taken when the red pyramid was not lit and the car was driving fine.
    Summary:
    Only happens on hot days (over 100*F)
    Some weeks it does it every day, some weeks not at all.
    Instead of going into R it goes to N
    Once stranded in N it will not let you power down.
    Once stranded in N it will not give you a mph 0 reading (as if ignition isn't on)
    Gives you the red pyramid and the warning screen listed in my first post.
    Now picture my wife and 2 year old stranded in the street in a 120*F car that won't run and the a/c won't turn on. Today it took 15min. for it to go into drive. Exactly what happened today!
    all help and suggestions appreciated.
  10. Highspeed
    16
    PNW
    Oh ya, dealer recommended replacing my optima with a Toyota battery... even though they did a load test on my optima and it was good - and putting on the e-break before pushing Park.
    I laughed uncontrollably. maybe I'll just trade it in for a new Insight.
  11. Patrick Wong
    18,210
    6,517
    DTC C2300 "Act System Malfunction" - possible trouble areas include the shift control actuator, transaxle parking lock control relay, transmission control ECU, or wiring harness.
    DTC C2318 "Low Voltage Error" - this is logged when battery voltage at the transmission control ECU is measured to be 9.3V or less. Possible trouble areas include the HEV fuse, IGCT relay, wire harness, or 12V battery.
    I can see that this is a serious problem esp. when it happens to your wife and child in hot weather. It sounds like the dealer is not able/willing to take any action since the problem is intermittent and probably cannot be duplicated at the dealer's site.
    If this were my vehicle, I'd be inclined to replace the following parts in this order, assuming that the 12V battery is fully charged and in like-new condition when the problem occurs: IGCT relay, then P CON relay, then the shift actuator.
  12. Highspeed
    16
    PNW
    Thanks Patrick!!! you wouldn't happen to know if any of that is covered under the hybrid warranty would you?
  13. Patrick Wong
    18,210
    6,517
    I think that none of the items would be covered. If you buy the relays and install them yourself you might pay $75 each at your dealer's parts dept; less if you buy from one of the Toyota dealers that offer 25% discount pricing over the web.
    If you are mechanically inclined and have metric sockets you can probably replace the shift control actuator yourself; this would require getting under the car and finding the assembly mounted to the transaxle case.
    If you wish to DIY it probably would be a good idea to replace the HEV fuse first, since that should be the least costly item on the list.
  14. northwichita
    481
    102
    29
    Wichita KS
    Any time I read this, heat plus electrical problems, I wonder if the problem is a inverter that is not being cooled, thus giving electrical problems. Do you have good circulation in the inverter cooling system? Maybe the pump is slowing down or other cooling problems . If you have an infrared thermometer, check the inverter case when you have the problem, mine runs under around 120 degrees on really hot days. FYI when my inverter pump was out(and I didn't know it), I was able to drive about 30 minutes with the a/c on before I had the dtc's show up. Opening up the hood, the inverter I could tell was very hot.
  15. Highspeed
    16
    PNW
    It seems to only happen when the car has been parked for a while. Today it did it after sitting over night. 10am it was just over 100*F and it didn't do it again all day. This is the normal way it goes these days.
  16. Patrick Wong
    18,210
    6,517
    If the problem usually happens upon first startup, then you can rule out the inverter coolant pump as an issue. That might be a suspect if the car has been driven for a period of time and then develops a symptom. However other DTC would be logged in that case, relating to the inverter overheating, while other ECUs would also report low voltage on the 12V bus.
  17. blacksquid
    blacksquid New Member
    Glad I found this thread!
    I've got a 2005 w/over 100K miles on it. Never had a problem until Friday and now this. My car has been at my dealer for the last couple of days and they really don't know what's going on with it. They have seen the problem however so that's a good sign.
    I suppose that after 5 years it is time to change the batteries but I have one question for those who have experienced the "transmission lock" problem:
    Did replacing the 12v battery resolve your issue with the message and the car not starting?
  18. Highspeed
    16
    PNW
    Please keep us posted on the findings. My Prius problem is still unresolved but the issue has been quiet all winter. With summer around the corner I have a feeling the issue will come back.
    Replacing my 12v battery did not change my issue.
  19. blacksquid
    Thanks for the update Highspeed!
    My car is still at the dealership. I was out of town over the weekend but my service rep left a voice message on Saturday that my car seemed to be ok even though they couldn't identify nor fix the problem.
    They've got volt meters at both ends of the car. The meter at the back is reading a solid 12v but the meter at front is showing strange voltage drops.
    I called this morning with the intention of picking up my car when I got back into town and the service rep went out just to make sure that everything was ok. Well, the good (??) news is that the car is acting up again so I hope they can isolate the problem.
    I wonder what is going on with this issues and I hope that Toyota is working this as well. Seems that more that a couple of folks have this problem.
    I'll keep this thread posted.
  20. Patrick Wong
    18,210
    6,517
    That implies a loose cable connection, or a damaged battery cable between the two meters. The 12V battery cable runs with the high voltage traction battery cables along the bottom of the car, driver's side.
