Caution: The transmission lock mechanism is abnormal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Highspeed, Jun 29, 2008.
  1. jPark
    jPark New Member
    Tried to have the code pulled at the dealer. they said no codes were present. Wth..?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    That would say, as is usual, that your 12V battery, or the connections to it, have a problem. If the parking lock mechanism was really stuck or damaged, then there would be a consistent code (P3102-xxx). But if it is 12V related, it can be transient and not stored once the car is in ready mode.
    #102 nh7o, Mar 6, 2015
  3. jPark
    jPark New Member
    I had replaced my 12v thinking that was the issue. The car drives fine with no issues. It's strange.. and only happens when I drop to 3mph. I can drive from 1-2 and it won't appear.
  4. nh7o
    1,686
    340
    Hawaii
    Have you measured the actual battery voltage at the jump points under the hood, with loads on and off? This is the only objective data. Over the years we have seen sufficient 12V replacements that were not charged, or defective, or had loose connections, that verification is necessary.
  5. jPark
    jPark New Member
    I'll check the voltage at the jump points as well as the connection points on the battery
  6. Num1mominal
    Num1mominal New Member
    Birmingham
    My issue was the battery pack and the 12v battery. Goodluck
    Go to auto zone and get diagnostic test but make sure codes are cleared first. My problem ended up being the battery pack and the 12v battery. Goodluck
  7. jPark
    jPark New Member
    battery pack as in one of the many hybrid batteries?
  8. bisco
    52,918
    the hybrid battery is made up of many individual cells, and some refer to it as a pack. like a six pack.:)
  9. pndwind
    pndwind Junior Member
    35
    My 2005 had this exact problem all lights on the dash were on. The MFD was giving the "Transmission lock mechanism is abnormal"
    and the red car with the exclamation point and "problem". The ICE would not start and the car would not shift into drive or reverse only into neutral after numerous tries and it would also hold no codes. So I pulled the 12v and it only had 9.5v. I pulled my optima out of my 2006 and put it in the 2005 and that solved everything. When the 12v in the 2006 needed replacing none of this happened but the battery was at 11v. It's amazing the issues one little 12v can cause.
    #109 pndwind, Feb 6, 2016
  10. pndwind
    35
    Well.........all lights were off for about 60 miles......then most of them came back on, but the transmission lock is abnormal warning is still off. :)
  11. bisco
    52,918
    looks like you need to read the codes.
  12. pndwind
    35
    It's not showing any codes. Should any OBDII work?
  13. Patrick Wong
    18,214
    6,531
    No.
    Get Mini VCI.
  14. farmhousenewbie
    farmhousenewbie New Member
    16
    Nashville, TN
    Having the same issues. Following the advice of the threads, I changed my battery after getting the "problem with the p lock mechanism" error with the red triangle. I replaced the battery and drove about 40 miles before the triangle popped up and the highlighted vsc and the yellow exclamation with it too. The cars cruise would bot work after that but I was able to drive to the dealer. The codes i got were - p3102-581 and c2301 with 40 and 50. Dealer wants to keep my car on monday to diagnose the issue. Help!
  15. JC91006
    16,939
    8,647
    If this is already at the dealer, you can leave it up to them to help you find the problem.
  16. farmhousenewbie
    16
    Nashville, TN
    yeah that makes sense. Lets leave it for $700 worth of trouble shooting and then parts and labor on top of that.
  17. bisco
    52,918
    what are you reading the codes with?
  18. farmhousenewbie
    16
    Nashville, TN
    The codes were given by the dealer. I took the vehicle in when the problem occurred.
  19. bisco
    52,918
    and they said the codes don't lead to the problem?
    how many miles on her?
  20. farmhousenewbie
    16
    Nashville, TN
    They said they will need it most of th day so they can find the cause. 161k. I did check the battery this morning and it was 12.1 after sitting all day. I turned on the headlight, dome lights, and wipers and it dropped to 11.5
