Caution: The transmission lock mechanism is abnormal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Highspeed, Jun 29, 2008.
  1. bisco
    52,878
    too many reports of new batteries being low and needing a charge, or bad altogether. where did you get it?
  2. farmhousenewbie
    farmhousenewbie New Member
    16
    Nashville, TN
    Oreillys. It the optima yellow top. Ill charge it and see if that changes anything.
  3. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Hopefully you are using a more modern charger with an AGM (Absorbed Glass Mat) setting. These chargers know to charger the battery to a higher charge, then shut-off. Older, non-AGM chargers will cut off prematurely.
    If you don't want to buy an AGM charger, read Optima's suggestions on how to properly charge the battery.
  4. Plockmech
    Plockmech New Member
    MA
    I've tried to reset p lock mechanism after 12 volt replace, removed 7.5 depressed emergency, still on
  5. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Welcome to PriusChat.
    Sorry, but have no idea what you mean. Perhaps you could give some background and explain in more detail what problem you are having and the remedy you tried so far.
