Featured Cayenne Poss. Hydrogen Sulfide from wrong 12v Battery
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by wjtracy, Oct 5, 2016.
  1. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    It's also worth noting that the Cayenne can have a second 12 volt battery in the rear, near the spare tire, in addition to the one under the driver's seat. (They do all sorts of stuff with load management, and disconnecting one battery upon shutdown, so that they can guarantee power is available for engine start even if the main battery is drained, if you have the second battery.)
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    1) I have for years tried to get folks to use the correct Prius battery. I feel it has been worth it that it was not a Prius in the news.
    2) Whiners who feel the Prius 12 volt is hard to replace should be required to watch that, and think how all that electric power seat movement is going to go with a dead battery!
    wjtracy likes this.
    52,915
    this is why we no longer own german cars.
  4. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    I wouldn't judge a car origin by one unfortunate event.
    But for sure I did judge VW group for prolongued lying.
  5. bisco
    52,915
    agreed, but we've had enough porche's, bmw's and mercedes to know you buy them for reasons other than reliability.
  6. Trollbait
    12,836
    I now wish I had fixed the broken vent tube on the HHR.
  7. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I have the VW version of the Dodge Caravan which is nice, but mainly it's a Dodge Caravan.
  8. Toppcat
    Toppcat Member
    223
    69
    Northern California
    That is sad to hear! not to comfortable about having a flooded battery in the cabin!I knowing what a overcharged battery cell smells like! Like rotten egg! gas burns the mucus membranes! That why most manufacturers are moving to agm batteries which are smaller, lighter, more powerful, but agm don't like to be fast charged, and over charged which leads to early failures! There fore they require a monitoring and regulating system.a anyone knows how much amperage the Prius inverter charges the battery ? I have notice on the scangage in the morning battery voltage is as high as 14.8 volts! After usage it's drops to 11.5 v a t times.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Yes sad. and even though the nose loses ability to "smell" H2S, like you say, it is not like you are smelling fresh ocean breezes at that point...rather you are getting unpleasant physical effects. Just hard to understand why a motorist would tolerate that without opening windows etc.
    Sources: Mom, daughter found dead in Porsche likely died from carbon monoxide | WFTV
    They have ruled out CO which is the more obvious possibility, but CO is rare these days too with the catalytic mufflers...but a 2006 could have break in the exhaust upstream of the muffler...we've had that in a few Prii. That's why I question scrapping the vehicle as has been reported. CO is not smelled so that makes more sense as a silent killer....nobody would question that, but we'd need a leak source of the CO.
    #29 wjtracy, Oct 7, 2016
  10. Trollbait
    12,836
    IIRC, 500ppm of H2S will kill the sense of smell with one inhalation. 1000ppm can kill with one breath. Those are tiny amounts in an enclosed car cabin.
    Sulfur smells on the road can be from a bad cat on another car. So if she did smell anything, and had time to ponder it, she might have thought it was from outside.
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
  12. Trollbait
    12,836
    That report was from June, long before the toxicity test results had returned. Responding officers reported strong caustic chemical odor upon opening the car; a couple were even hospitalized. CO itself is odorless, and I can't think of another agent being released along with it from the usual source in a car being as described. it also would have to get into the car from outside.
    H2S disrupts the cells ability to use oxygen for respiration, so the symptoms can mimic CO poisoning.
  13. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Maybe instead of a mouse living in the air filter she had a skunk?
    H2S is nasty stuff --->> Link to OSHA <<---
    100 ppm is IDLH - Immediately dangerous to life and health. It's also the level at which you can no longer smell it.
    500-700 pm = Staggering, collapse in 5 minutes. Serious damage to the eyes in 30 minutes. Death after 30-60 minutes.
    700-1000 = Rapid unconsciousness, "knockdown" or immediate collapse within 1 to 2 breaths, breathing stops, death within minutes.
    1000-2000 = Nearly instant death
  14. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Maybe, but the tox report sounds funny too...we might expect H2S metabolites in the urine, but to my knowledge not free H2S not to mention it is potentially a natural thing. I am not aware of a post-mortem test for H2S. Also H2S is smelly so you have to invoke sudden large shot of it. Possibly H2S was hanging out in the vents and then they turned on A/C. I mean it's not impossible to be H2S, but I think it sounds a bit questionable. Also H2S does not smell like ammonia and caustic as has been said in some articles. As far as I know, H2S does not cause skin to be red like CO does. Just saying not quite adding up yet, others saying this too.
    The thing CO and H2S have in common only is they bind to the hemoglobin, believe H2S is less strongly bound so its temporary if you can get some air.
    #34 wjtracy, Oct 7, 2016
  15. Trollbait
    12,836
    I don't think all the details have been released publicly; possibly for the upcoming civil suite. I've only seen mention that the battery was the wrong type; nothing on it being damaged or not. One of its cells could have ruptured, and suddenly flooded the cabin with H2S. That would also release hot acid, and I don't think many people can call the difference between caustic and corrosive chemicals when sensed, they both burn the nose.
