CCID Hanger
Discussion in 'Prime Plug-in Charging' started by schja01, Jul 9, 2018.
  1. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    I take it Toyota still does NOT include a hanger for the Charging Circuit Interrupting Device (CCID) even though it suggests hanging it on one and even goes so far as showing a picture in the manual.
    Assuming not, are the holes in the CCID large enough if I fashion one myself out of a coat hanger?
    Thanks,
    J
    Attachments.
  2. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Yes, the holes are large enough for a coat hanger. My solution was to run some nylon cord through the holes and hang it from a nail in the wall.
    schja01 likes this.
    52,863
    toyota fail. again. i would call an engineering firm for professional advice.:LOL:
  4. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    I think I was over thinking things. THANKS.
    J
  5. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Here is what I did. Go to the Home Depot and buy a key ring, a carribeaner key chain and 2 feet of plastic chain. Put the key ring through the hole in the bracket and then attach each end of the chain through the Carabiner and loop it through the keychain. You can adjust the chain length to suit your needs, whether you loop it over a nail, or the electrical box. Total cost is less than $6. 20180709_184244.jpeg 20180709_184325.jpeg
    schja01 likes this.
  6. bisco
    52,863
    i use a bungee cord, 65 cents.
  7. Mark57
    2,945
    2,740
    OK
    I just used a single strand of insulated 8 gauge copper wire. Strong but pliable.
  8. Mendel Leisk
    42,354
    Couple I've got:
