CD player problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by The Limey, Mar 20, 2015.
  1. The Limey
    The Limey New Member
    England
    An issue with my Gen II. It has the 6 CD changer, yet when I press the button for the unit to accept a new disc nothing happens. Any ideas? Is it busted, or is there some way the unit can be reset?
    My car also has the JBL upgrade. Is this just speakers, or is there a separate amp too? If I fit an aftermarket head unit will it just plug straight in, or am I going to find grief?
    Thanks guys,
    Rich.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    the separate amp under rf seat (since y'all drive on the wrong side of the road, I can't say passenger seat) incorporates some of the radio functions. so to change the head unit you will need to buy the correct interface unit to make it work with the jbl amp. or replace the jbl amp too and rewire the whole mess. still need interface for steering wheel buttons to work.
    The Limey likes this.
  3. The Limey
    England
    just checked, does indeed have an amp.
  4. 69shovlhed
    2,170
    746
    Delaware
    only other thing you might try is pull the fuse for the head unit and see if it will reset.
  5. nelmat
    nelmat New Member
    Techs at crutchfields will help for free. Also prices ain't bad if you want to replace
