CD player?
Discussion in 'Gen 4 Prius Main Forum' started by Jerry P, Dec 4, 2020.
  1. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    I’m planning on buying an 2021 XLE-awd soon and I can’t find if the audio system has a CD player included. Does anyone know? Thanks for you help.
    Jerry
  2. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Yes, I know, and no, it doesn't. CDs are consider old tech.
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I bought a portable CD player (about $30) to use until I can justify spending several hundred for a third party CD/DVD/Stereo replacement system for my 2020 AWD-e Prius. We use CD "Audio Books" from the library when on trips.
  4. Tideland Prius
    16,680
    Huh. It looks like they removed the CD player in the 2021 models, even on the 7" MFD.
    alanclarkeau likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Oh, really? Is that true for the Prius Prime LE model as well?
    BTW, this thread may need to be moved to Gen4 forum?
    edit: I checked the 2021 PP specs. Yap, the 2021 PP LE still has a single CD player.
    #6 Salamander_King, Dec 5, 2020
  7. fuzzy1
    10,707
    CDs are going the way of 8-tracks and cassettes.
    Copy them to USB thumb drives, while you still have a computer with an optical drive! Some people may already need to buy a separate USB-plug optical drive.
    And note that for most ordinary mortals, you can now put your entire music collection onto a single USB thumb drive.
  8. alanclarkeau
    7,045
    7,593
    Except - that's fine for Podcasts. But MUSIC (Classical) - a USB just doesn't cut it - CDs are how I listen to it.
    Tideland Prius likes this.
  9. Tideland Prius
    16,680
    So the Prime has a CD player but the regular Prius doesn't? LOL.
    Same. When I still had my Gen 3, there was a noticeable difference in sound quality between using the CD player (changer) and Bluetooth Audio from my phone. The CD was a CD-R with MP3s too. Of course an actual store bought CD sounded that little bit better than the MP3 CD.
    I can't test with my Prime since I don't have a CD player but I do use an iPod with a wired connection instead of bluetooth audio to try and retain some fidelity.
    Definitely, having my entire music collection is handy but I also appreciate audio quality. (Well, as much as can be done in a vehicle environment)
  10. pianewman
    264
    183
    2018 Prius
    I'm with you on this. I gave up listening to Classical music, in fact, any music, in the car years ago. What passes as good audio fidelity these days isn't as good as a pre-WWII vinyl disc. Seriously!!! (Toscanini, Horowitz)
  11. Salamander_King
    11,024
    8,978
    New England
    Also, all Prius lines except the L Eco comes with Intelligent Clearance Sonar (ICS) with Intelligent Parking Assist (IPA) and Blind Spot Monitor (BSM) with Rear Cross-Traffic Alert (RCTA) whereas those features are available only in Prius Prime Limited.
    #11 Salamander_King, Dec 6, 2020
  12. Tideland Prius
    16,680
    I guess because the Prime costs less than the regular Prius after tax credit, it gives a bit more incentives to buy the regular Prius.
    alanclarkeau and Salamander_King like this.
  13. fuzzy1
    10,707
    Between the impairments of the vehicle equipment, the very high noise floor during driving, the somewhat low volume caps I insist upon to delay the hearing losses witnessed in those around me, and the age of my ears, the higher bit rate versions on USB (direct plug-in, not Bluetooth) are perfectly good. And lower bit rates for podcasts.
    To hear the difference of the full CD copy, I'm going to need better equipment in a quiet studio-like environment. A moving car doesn't come anywhere near close.
    But the bit rate of raw uncompressed CD-Audio data is easily within the transfer rates of even the old slow original USB standard, let alone the much faster modern versions. And with terabyte USB flash drives now available, one can now put a thousand raw uncompressed CDs onto a single thumb drive.
    Does anyone make head units that can play full CD-Audio-format data from the USB port? There is no technical reason not to, and the benefit of getting rid of the physical plastic disc from the automotive environment, is considerable.
    (Or does DRM preclude this path? The last time I copied full audio CDs was on a PC predating much of the DRM.)
    kevinwhite and Tideland Prius like this.
  14. Tideland Prius
    16,680
    I've avoided USB thumb drives in Toyota headunits since they don't seem to play well (or takes forever to index each time you start the car). I found the iPod indexes more quickly and is less finicky. But given that the only iPod left is the iPod Touch which is much larger than my nano, I won't be "upgrading" any time soon. Even if the USB is not hidden (e.g. under the dash like it is in the new Corolla where I can't hide the iPod), I'll just switch to BT Audio since I have a duplicate copy of my library on my phone.
    fuzzy1 likes this.
  15. fuzzy1
    10,707
    I use this size drive, which is closer to a little fingernail than a whole thumb. Two almost identical copies, one in each car, copied from a master collection on a tower PC. Users wishing terabyte capacities still need whole-thumb sized devices, not these fingernail-sized ones, at least until next year :) :
    That long indexing delay is annoying, but I'm seeing it only after changing device contents. After other car restarts, it seems reasonably quick. The headunit must have a way of knowing when it needs to re-index, vs. retaining the previous index.
    New a couple months ago, the drive in my Prius began sometimes freezing the headunit. It started right after wiping it clean and reflashing a refreshed 30GB collection all at once, leaving the device very hot, possibly overheated. Swapping drives between cars seems have fixed or hidden the problem.
    Tideland Prius and kevinwhite like this.
  16. alanclarkeau
    7,045
    7,593
    The other thing I've found is that USB drives aren't very reliable. Over the years, I've tossed quite a few out. And some which will work for a transfer between laptops, won't work in the PRIUS.
    Proper Audio CDs, never had a problem with any.
    CD-RW - I've got about 20 - and only tossed 1 or 2 in many years I've been using them.
    Mendel Leisk and Tideland Prius like this.
  17. fuzzy1
    10,707
    OTOH, of the old data CDs from my old workplace (20th Century), the handful that I have checked, are all now unreadable.
    I still have my factory-stamped music CDs, so can go back to them if the multiple flash and HDD copies are all lost. Not having them in the car, helps preserve them. The oldest are now well past what we were originally told would be their life expectancy, though the sampling I've gone back to hasn't failed to read. I haven't looked up the more modern estimates of life expectancy.
    #17 fuzzy1, Dec 6, 2020
  18. alanclarkeau
    7,045
    7,593
    Some CD-R disks I've got were the same - they were made for a once-only burn. And I think some didn't have the same quality as others. We had a good run with VERBATIM CDs (but they make terrible USBs). I have the feeling that CD-RW were better quality generally - (for higher $$€€ ££). We did use CD-RW for computer backups briefly but went to DATs, which they were using when I retired.
    fuzzy1 likes this.
  19. fuzzy1
    10,707
    Mine were just CD-Rs, because the price difference compared to CD-RWs was enormous, and I wasn't expecting to reuse CD-RWs enough times to make them worthwhile.
    And the types used very different materials for the data layer. Had I known of CD-RWs expecting to have a longer life expectancy, I would have switched at some point, after their prices came down.
    I first bought some CD-Rs back when they were about $20 each. Back when that was still real money. Sold only as singles, long before they became cheap enough to put in those cakebox stacks without armed guards. Burn session setup problems on the first attempts were extremely painful. :mad:
    #19 fuzzy1, Dec 7, 2020
    Tideland Prius and alanclarkeau like this.
  20. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I adopted a backup strategy of using multiple (Rotated for redundancy) external hard drives for my file storage years ago. Since they are only spinning when doing a backup (or, much less often, recovering a file), they last a long time and they keep getting less expensive per MByte (GByte now). My web site files are stored in three places: My web server, My active PC (A Flash drive now, where I edit the files before uploading) and in the backup HDs for my PC. I never delete files, I just move to larger HDs when space gets low.
    CDs got too small a long time ago for backup and then DVDs became too small soon thereafter, hence my HD strategy.
    There is no reasonable substitute for CDs in a car for "Audio Books on Tape" when driving across country. We get the Audio books on CD at our local library for free.
    JeffD
