CEL with P3021
Discussion in 'Gen 3 Prius Main Forum' started by zfk110, Jul 22, 2022.
  1. zfk110
    zfk110 Junior Member
    97
    Atlanta, Georgia
    2010 Prius 3rd Gen with 160K, Im getting P3021, but my OBD meter doesn't have any info about it, with online searching it's saying block 11 is weak, I took the picture of battery, someone kindly tell me which is the block 11 on it? I put the arrow on it, IDK if its the right block or not? becasue when Im reading the volt its showing me 7.4 on each cell
    #1 zfk110, Jul 22, 2022
    52,858
    are you testing under load? what code reader?
    zfk110 likes this.
  3. zfk110
    97
    Atlanta, Georgia
    I was just driving around then CEL came up. when I put the reader INNOVA 5610 it shows me that code
    52,858
    when you test the module or block voltage, it has to be under load so you can see the actual voltage the car sees when you're driving
    zfk110 likes this.
  5. zfk110
    97
    Atlanta, Georgia
    How I can do the load test on these? also how I can find the block location? That what I was trying to find out
  6. bisco
    52,858
    tech stream can do a load test, possibly dr. prius app. or you can find procedure for individual modules in the rebuilding threads, as well as module block numbering.
