cell battery hybrid gen 3
Discussion in 'Gen 3 Prius Technical Discussion' started by Boursine P3, Jun 12, 2020.
  1. Boursine P3
    Boursine P3 New Member
    Senegal
    I am in senegal, i would like to buy parts or cell of hybrid battery, please advice where i can order cells for my prius's battery hybrid
    best regards
  2. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
  3. LukUsc
    LukUsc Member
    69
    26
    Poland
    Do You know how many cells you need and for some capacity You would like to rebuild the battery?
  4. Classic Car Guy
    Classic Car Guy Active Member
    502
    135
    Northwest, USA
    I have a question for my 2007 prius. Whenever I have the car on a long stop lets say on a drive thru station sitting for more than 12 minutes, the battery bar goes down to the last 'purple bar' then it charges. I'm not quite sure if its suppose to go down that fastfor I cant even sit on the car longer than a normal gas engine car. Do you think there is something wrong with the hybrid battery? If so.. what do you suggest?
    By the way the car is 150k miles and its well kept and driven normally.
    Thank you!
  5. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    if you can get an OBD2 bluetooth adapter and the DrPrius phone app priusapp.com and see in the menu at the top of the page OBD2 to buy
    Jack explains what he has experienced using different ODB2 adapters and which ones work best with his app.
    There are a lot of DrPrius users here that can help explain any screenshots and questions .
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No idea. There’s no purple bar on ours here just all white, unless you did the cool led mod that looks waaaaay cool!
  7. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    You might get more assistance if you post in the section for Prii of that generation.
    The battery will obviously discharge a lot faster if you have air conditioning on.
  8. james wang 20
    james wang 20 Junior Member
    65
    fiji
    If you have obd equipment, you can record the 10-minute data while driving. In the voltage data of each module battery (there may be 14 pieces), you can see that some cells rise very quickly when charging, and drop very much when discharging. Soon, then, the cell should be replaced.
  9. james wang 20
    65
    fiji
    The vehicle is in the ready state. Even when the air conditioner is turned on, it seems that it takes a few minutes to start the engine charging. If you wait all the time, the time for the engine to start charging is usually not as long as the silent time.
