Cell blocks read -25 and 0 on 3,4,5
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Devintcrouch, Aug 12, 2020.
  1. Devintcrouch
    Devintcrouch New Member
    Oklahoma
    I’ve bought 16 new modules and replaced as many as I can all volts are good but still have the triangle of death. I’ve bought a scanner and it shows Block 1 at -25 and blocks 3,4,5 reading 0 volts. I’m reading them right to left. I swapped the cells around to narrow it down and I’m still getting same voltage on same blocks. Is it the harness or ECU?
  2. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    High probability it is the harness and not the ECU. But check the pins of the orange plug in the ECU, to be sure.
    If it is the harness, buy a new WIRE, FRAME, NO.2 (PNC 82165C) Part Number 82165-47040 from your local or online Toyota parts dept. It will be the best $70 you spent.
    SFO and fotomoto like this.
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  4. ChapmanF
    18,940
    Block voltages coming out negative are usually telltale signs of damage to that harness or to the pins of the connector where it plugs into the ECU.
