Center console light installation
Discussion in 'Prime Accessories and Modifications' started by Insighter, Mar 29, 2018.
  1. Insighter
    Insighter Active Member
    409
    287
    SoCal
    One of the modifications I had done yesterday was the addition of a light to the center console. With everything being black, it was just too dark for me to see what's in it. So I had a small light added at the rear of the console. It looks sort of like the OEM cargo area light (without a switch, though). There's an LED bulb inside.
    With the sliding tray in place at the rear of the center console, you can't see the light, but you can see what's in the console. I had it wired so that it comes on whenever the car is on (instead of just when the headlights are on).
    Mark57 likes this.
  2. DavidA
    2,348
    1,823
    Chicago western burbs
    Nice!
    Can you offer a parts list here for anyone wanting to duplicate this project?
  3. Insighter
    409
    287
    SoCal
    I'm afraid my days of doing things like this DIY are over. I can ask my installer what he used when I go in next week.
  4. DavidA
    2,348
    1,823
    Sorry. I had thought that was your own DIY project.
  5. Insighter
    409
    287
    SoCal
    No, I used to do things like this all the time in cars I had in the past, but I don't have time now.
  6. Mark57
    2,945
    2,740
    OK
    Very nicely done and a very good idea.
    Insighter likes this.
  7. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Cool! So, from what I read, there's no "on/off" switch, it just comes on automatically when you start the car. Is it at all distracting at night?
  8. Insighter
    409
    287
    SoCal
    Thanks. There is no switch, but I don't understand your question. How could it be distracting? If the center console is closed, there's no possible way to see the light.
  9. Mendel Leisk
    41,877
    Add a switch so the the light only comes on when the armrest lid is raised? Like a fridge light.
  10. Insighter
    409
    287
    SoCal
    But why would you do that? A small LED bulb hardly draws any juice. Why add the cost and complication of a switch?
  11. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Wondering if you might see a line of light in your peripheral vision, around the lid. I can't imagine that being a problem. Just curious.
  12. Insighter
    409
    287
    SoCal
    No, not at all. Put a bright flashlight in your center console and check it out.
    nednvermont likes this.
  13. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Mine has the light too.
  14. Insighter
    409
    287
    SoCal
    What did you put in there? I know it's not the most important mod, but it is nice to have a light in there, isn't it?
  15. randomwalk101
    532
    271
    texas
    I was running a couple wires for this mod (see below) so decided to installed a tiny LED in there (copied your idea). Only took me a couple minutes.
    Japanese version panel | PriusChat
  16. Insighter
    409
    287
    SoCal
    Great, that's why I post (in case someone else wants to do the same thing), and why I look here to see what others have done.
    I attached an all-stainless steel camping mirror to the underside of the tray to distribute the light in the center console more evenly (and having a mirror on hand can't be bad). It makes a big difference in the effectiveness of the center console light.
    Chazz8 likes this.
  17. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    Would aluminum foil offer the same results, less the $12
  18. Insighter
    409
    287
    SoCal
    It wouldn't offer the same result. The reflectivity would be different. It wouldn't be as bright, though it would probably be more diffuse depending on how flat the foil was, which might be better in some small way. Ultimately, it would definitely be less durable, and you wouldn't have the functionality and convenience of always having a mirror on hand in the car.
  19. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Except for the flip down sun visor mirrors :)
  20. Insighter
    409
    287
    SoCal
    True, but those aren't removable (at least not easily). If you wanted a mirror to use outside of the car or in the backseat, the mirror on the tray would work, but the visors wouldn't.
