Japanese version panel
Discussion in 'Prime Accessories and Modifications' started by citiprius, Mar 11, 2018.
  1. citiprius
    citiprius Active Member
    241
    236
    51
    2018 Prius Prime
    Found on Japan Amazon (use google translate please) this new panel with 2 USB, cost around $80 USD. I hope they have the US version:
  2. stinkytofu74
    stinkytofu74 Junior Member
    Pleasant Hill
    Don't need google translate. When you're on Amazon JP, you can select EN for English in the language select drop down.
  3. SaraBBrown94
    SaraBBrown94 Active Member
    234
    262
    Pittsburgh PA
    I bet someone could do something very similar to this for much cheaper because I doubt we'll get this. Japan always gets all the goodies.
    Get a couple tiny LED bulbs and wire them behind the shifter panel so it just glows around the shifter since there's space in there. The USB ports could be dremeled and wired in... It would just take someone knowing where the power could be drawn from and what to attach them to.
  4. randomwalk101
    randomwalk101 DYI'er
    532
    268
    texas
    Hey Sara
    I’m ordering some round LED ring and will install that light soon. :)
    SaraBBrown94 likes this.
  5. randomwalk101
    532
    268
    texas
  6. SaraBBrown94
    234
    262
    Pittsburgh PA
  7. randomwalk101
    532
    268
    texas
    Sure. Run wires is easy part. I already did that.
    The hard part is whether the ring will fit. I measured that hole is 60mm. Hopefully the ring will fit.
  8. SaraBBrown94
    234
    262
    Pittsburgh PA
    If it didn't you could always put it inside the open areas and just let the glow indirectly come in through the crevasse.
  9. randomwalk101
    532
    268
    texas
    Got the led ring today and it won’t work mounting inside that hole 1) you see spots on the ring this don’t look right 2) the ring with cover is a tad bigger than the hole.
    I just ordered the 80mm white led ring this time and mount inside instead. Should be here sat :)
  10. randomwalk101
    532
    268
    texas
    Well Sarah. The 80mm works. Plenty bright even it only shines through the crack as you suggested...but not blinding or in real life. I like it :)
  11. randomwalk101
    532
    268
    texas
    A few more shots with garage light on
  12. randomwalk101
    532
    268
    texas
    Black appliqué or no???
  13. SaraBBrown94
    234
    262
    Pittsburgh PA
    I prefer the black. It looks like it reduces the amount of light too which might be better in terms of night driving and eye acclimatization.
  14. randomwalk101
    532
    268
    texas
    Yeah. I put in the black appliqué this morning. I drove without it to a friends house over the weekends (night) and the brightness was too much at night. Daytime it’s perfect.
    I’m getting a dimmer to dim it at night when the headlight is on. Will see :)
  15. VVTiBob
    VVTiBob Member
    45
    29
    What about just connecting it to the same circuit that controls the brightness of the dashboard lights? Then it’s adjustable with that single control.
