Center console storage - missing piece?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tandy, Jun 24, 2018.
  1. Tandy
    Tandy New Member
    IL
    I just bought my 2015 Prius and I’m not sure if I’m missing a liner or something in the center console. It doesn’t seem like it should just be blank plastic. Can anyone show me what I’m missing? Would an insert like the Carmate work without the missing piece? Thanks!
  2. Tideland Prius
    16,206
    Your instincts are right. There should be a thin felt piece that lies on the base of that.
    It should work since it's the CarMate use is not contingent on that thin felt piece.
  3. Tandy
    Tandy New Member
    IL
    Thanks! I didn’t want to buy that not knowing what I was missing.
  4. Tideland Prius
    16,206
    Finally got around to the pics.
    Here's the tray with the felt lining.
    I've taken it out and folded it to show you both sides at the same time. The foreground is rougher and is the underside of the lining. The background is a smoother, softer material. Not shown is the velcro that holds the lining in place. Your photo appears to be missing the velcro as well (it goes in that square spot)
