Center floor side member extensions plugs?
Discussion in 'Prius c Main Forum' started by Oldwolf, Jun 19, 2012.
  1. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    I found a plastic bag in glovebox that says in capital red letters: IMPORTANT
    Then below it says "To pre delivery inspector: Insert these rubber plugs into the holes of the center floor side member extensions."
    Where are the center floor side member extensions?
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I found them there too; there's a thread here that describes where they go, and there should also be a diagram on the back of the bag.
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yup.. it just pops in.. just poke your head under the car towards the back.
  4. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Mine does not have a diagram on the bag. Guess I will poke around the car tonight.
  5. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    As Squall said, just pop your head under each side of the car and you'll see the holes about a foot forward of each rear wheel.
  6. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Will do, thanks.
  7. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    So I installed the plugs tonight. The fitment didn't seem too water tight. I hope these plugs don't leak and keep water in instead of out.:cautious:
  8. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    I put gasket sealer on mine just to be sure they sealed off good.
    JD
  9. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    I thought about that myself xhch2. I might use some RTV on them.
  10. Mike500
    Mike500 Senior Member
    2,593
    764
    I've found these pulugs to be in two varieties.
    The ones that came with my Prius "v" were made in China and were quite thicker and stiffer.
    The ones made in USA were thinner and fit looser.
  11. donny612
    donny612 "Captain Jack Sparrow"
    117
    Apex, NC
    Now why do you suppose the dealer, or the port didn't install them??? That would be the question...
  12. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    The plugs from my Civic fit the Prius perfectly.
  13. Rainman16
    Rainman16 New Member
    willis tx
    2015 Prius v wagon
  14. Rainman16
    willis tx
    2015 Prius v wagon
    I purchased a 2015 V and it still has the plugs in the glove box. I got on line to find out where they go. After finding out and finding the hole I placed my LED light into the hole and light shine all over! A lot of holes and slits so it does not seal anything! Maybe we are missing the right holes? I will ask techs on my 10K oil change.
  15. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    Here is a picture of mine, they were also in the glove box. I spent a couple minutes looking up front but thanks to the thread it was an easy fix.
  16. Mendel Leisk
    38,726
    Pre-Delivery Inspection isn't what it used to be. There's a raft of things the dealership is supposed to do; sadly they tend to "mail it in", consider the PDI their "tip".
    Better double-check all the tire pressures too, including the temp spare. And fluid levels, etcetera.
    Email the service manager, you might get some freebies.
  17. JimBobWay
    JimBobWay Junior Member
    2021 Prius
    XLE AWD-e
    Thank you for the photos and help from all. I just picked up a 2021 XLE-AWDe and the same plugs are still in the same place... THE GLOVE BOX.
  18. Dan Y
    Dan Y Junior Member
    50
    Brooklyn, NY
    2022 Prius
    LE AWD-e
    And my wife and I just bought a new 2022 LE-AWDe and the same things in the glove box and Googling led me here. I'm wondering, what do these plugs even protect?
