Center screen MFD not lighting up? Voltage at panel fuse #17?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Feb 25, 2025.
Tags:
  1. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    OK, here we go
    So a new to me 2007 prius, NON jbl, center MFD screen wont light up. I sent it out to Autobeyours for a refurb. It comes back and still wont work. Radio turns on, clock works, odo button works, but no screen. now, there is a Fuse labeled "#17 PANEL" 7.5 amps. After working with a volt meter all the fuse electrodes read 12V except this one. with the fuse out, it reads 8.76 volts. with the fuse in it reads zero. any idea whats next?
    Ian
  2. JC91006
    16,939
    8,647
    How much did they charge for the refurbish? You are talking about the center screen that controls the AC and Radio functions right? Maybe they didn't do a good job at the refurbish
  3. Ianmeister
    316
    320
    Meridian Idaho
    it was like $300. I dont think the problem is in the screen
  4. JC91006
    16,939
    8,647
    Is it doing anything different than when you first got the car?
  5. Ianmeister
    316
    320
    Meridian Idaho
    WHOOPSIE!! turns out that fuse #17 is only hot when the headlights are on, and the problem was fuse #13 ECU-B! new, fuse in, MFD works better than any I've seen. woohoooo!!
    gdanner likes this.
