Central locking problem.
Discussion in 'Generation 1 Prius Discussion' started by Ash Bennett, Apr 21, 2016.
  1. Ash Bennett
    Ash Bennett New Member
    England
    2001 Prius
    I
    I have a problem with my central locking, I changed the battery in the fob but it won't lock the car, if I lock with the key the fob will unlock the car. When I press the lock button there is a clunk-clunk as if the central locking is working and I can hear the noise in the doors and the boot but nothing happens. The battery was totally flat and I haven't been using the fob for a long time but I seem to recall it used to lock. Any help would be appreciated.
    #1 Ash Bennett, Apr 21, 2016
  2. LEVE
    LEVE Member
    191
    97
    On the Willapa
    I would go through the fob reprogramming sequence to lock/unlock the car. I just did this last week for my 2002 with a remote fob I've had sitting for a couple of years. I put in a new battery, reprogrammed and it works like a charm. I followed the steps located here:
    Coastal Electronic Technologies, Inc. Reprogram sequence
    It's not impossible the fob is bad. I had two proximity remotes for my 2005 Prius that do not work. One doesn't open/lock doors but will start the car. The other will open/lock the doors but won't start the car. Now, $150 later with a new dealer supplied remote... I have a fob that does everything. No amount of programming would budge those two older remotes, including programming with a Toyota Handheld scanner... So, in short, be prepared to buy another remote. They're available on Ebay.
    Ash Bennett likes this.
  3. Ash Bennett
    England
    2001 Prius
    I
    Thank you Leve. I tried but it didn't work, it seemed to go through all the stages. When I press lock it clunks and the indicators flash twice but it doesn't lock. It did lock once when I was sat in the car though lol
  4. ChapmanF
    19,027
    If the car is already responding to the fob in some form (such as unlocking the doors), the programming has already been done.
    If you hear sounds from the car when you tell it to lock, but it then is not locked, probably one of the lock actuators is weak, and is not able to move its door fully to the locked state. The car detects that, and responds by fully unlocking again. You may be able to see this by looking through the windows to watch the door lock knobs while trying to lock with the fob.
    Why the car's reaction to an incomplete lock is to fully unlock, is anybody's guess, but I guess they figure that way you will notice the problem and wonder how to fix it. The answer is to find which door's actuator is weak, and replace the actuator. There are other threads on that.
    -Chap
  5. bwilson4web
    16,537
    A weak 12V battery could be involved too. It would be worth while to measure it with the car off for an hour our so.
  6. Ash Bennett
    England
    2001 Prius
    I
    It's a new battery, fully charged.
  7. bwilson4web
    16,537
    That is why we measure the voltage when the car has been off for an hour or so. Measurement removes all doubt.
