Central locking won’t lock doors, but then will?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zackel90, Mar 16, 2024.
  1. Zackel90
    Zackel90 New Member
    Sydney
    i-Tech
    Hi guys,
    the car doors won’t lock when leaving car. But then if I go away for a couple of hours and then they will work as normal. But as soon as I put the key in ignition and start car. Take key back out it won’t lock again.
    • no button under steering wheel to turn off and on
    • changed battery on key fob
    • Reprogrammed key fob
      • Open doors x 2 and key ignition x2 and repeat. Locks did the sequence to say at the end it worked
    • Replaced car battery.
    Maybe replace key fob completely or go see an auto electrician to fix sensor?
    Any suggestions would be greatly appreciated!
    thank you for any help​
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    Tech software and check programming or locksmith can do probably
    Zackel90 likes this.
  3. Zackel90
    Zackel90 New Member
    Sydney
    i-Tech
    As in the car software and programming?
  4. Zackel90
    Zackel90 New Member
    Sydney
    i-Tech
    Hey just wanted to confirm what you mean?
  5. Tombukt2
    13,867
    2,520
    Durham NC
    Yes the tech stream software and or the locksmith software that goes with the machine that does all the work with the transponder keys I can't remember the name of the machine that they all have.
