Chains? Snow tires? How do you do winter with these
Discussion in 'Gen 5 Prius Accessories and Modifications' started by lohikaarme, Sep 3, 2023.
  1. lohikaarme
    lohikaarme Active Member
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    many if the states have winter chain laws, however, there are no chains for the 19” wheels. How do you guys do it? Downgrade to 17” wheels where chains fit + snow tires for the winter? If that is the case does it throw off your speedometer? What about the tire pressure sensor? Im guessing just drive around with the low tire pressure warning on dash for a few months?
  2. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I drive in Oregon and Washington in the winter. On many of the mountain passes or in the Columbia Gorge, signs will say carry tire chains or use winter tires. It's not the snow you need to worry about, it's the ice. I use Michelin X Ice in the winter with no chains. They work great and have never had an issue with traction. Blizzaks work great too but I get the Michelins since they have a 40,000 mile warranty.
  3. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    But they are not available for the 19” wheels, all new rims?
  4. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Yes, I'll be permanently changing over to 17" wheels and tires in the late fall.
  5. Mendel Leisk
    42,330
    I would think so; steelies with snow tires are always a good idea in the snow belt, and maybe once in a blue moon if you must have chains you're set. I think the percent of vehicles that use chains is very low.
    Too: if chains are required, maybe it's best to just wait a few days, till the weather clears. Especially with a Prius or similar, low-slung vehicle.
    The OD's of stock 19" and 17" tires are roughly the same.
    That's been working for me. In some* US States though, there's annual inspection that'll fail you with a TPMS light though. Maybe try to get the inspection in summer?
    * TireRack has a list of those States IIRC
  6. fuzzy1
    10,705
    A second wheel set can have its own TPMS sensors, and their codes programmed into the system for the season. This does cost a bit more, but provides TPMS coverage year-round.
    If you want a shop to put the wheels on, this is mandatory in the U.S. To go TPMS-free, you must put the wheel set on yourself at home. If you don't like seeing the warning light, black electrical tape is very cheap, easy to install, and easily reversible.
    As for tire chain enforcement in WA, AWDs are required to wear them only very rarely. When it gets bad enough for AWDs to need them across the Cascade passes, WSDOT usually just closes the roads entirely, especially across Snoqualmie. While technically you must still carry them just in case (though only when winter traction requirements are posted), they seem extremely lax in enforcing even 2WD and commercial trucks requirements until the violators actually crash or get stuck and cause traffic blockages. If you are not one of the stuck vehicles, your risk of needing to show your chains in an AWD is negligible. While I do have chains in every household vehicle in winter, even in the AWD, it is more for potential problems elsewhere in our travels, not the usually well-maintained, well-groomed Cascade passes.
    Traveling in other states may be different. Though one time when we was crossing I-80 Donner Pass much later in the autumn season than planned, with unseasonably early winter conditions, and a chain checkpoint officer was turning back almost everybody, he let us through simply because we were driving a Subaru, without even checking to see if we had winter tires on or carrying chains inside, which we didn't (yet).
  7. fuzzy1
    10,705
    In the places in WA where chain requirements are typically posted, one usually needs to wait only a few hours until requirements change. Sometimes for the better as traffic wears down through the snow and ice, sometimes for the worse as the road gets closed completely.
    On the major highways, if it is a ground clearance issue for low cars such as Prius, the road is almost certainly closed. Ground clearance should become an issue only on lesser roads without full time grooming.
    For the OP in WA, there is no such inspection. Other than the emissions checks, now ended, the only "inspection" I've ever faced was a pre-registration check to make sure the vehicle I brought into the state when I moved here, wasn't stolen.
    #7 fuzzy1, Sep 3, 2023
  8. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    I sent a email off to peerless to see if I could get away with using the below chain. The tensioned side would hang lower on the outer walls. The inner wall would remain the same, for those that never used this chains, you close a steel loop on the inside wall, pull out the cables and close the loop on the outside wall and then they auto tension. I dont think they could slip off the tire, the inner loop would be centered as tension would be all distributed evenly. The chain pattern on the tire would not be centered as displayed, the outside wall hanging lower would pull the pattern more to the outside of the tire tread both because the stock tire is shorter and narrower at 195/50 R19
    It may be that they have a size that will actually work but because this is such an oddball tire they have not yet listed it. It may not be a case where there is simply nothing that could work. I will report back when I get an answer.
  9. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    there is also one rated at 225/45R19 and 225/40R19 so getting even closer trading wall for width
  10. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    I was out to try to get chains because I will need to be crossing the country in January. I was looking to do this as a one time thing so as not to have to do two sets of tires. I think I am going to give up on the quest though, I just cannot find chains that actually fit. Peerless wont recommend because the manual explicitly says no chains.
    I "borrowed" some chains from amazon to see if I could find a working set but something is wrong with my math.
    The stock tire is 195/50 R19. The 50 is the aspect ratio of the thread so 195x.50 = 97.5mm side wall and 195mm tread width.
    I tried two different chains:
    225/35r19 and 225/40r19
    The general thinking
    225x.35 = 78.75 side wall + 15mm (which wild be the 225 - 30 to bring it to 195, and than that 30 /2) so these chains would have been ~ to 195 tread and side wall of 93.75 which is just 3.75mm shallower on the side walls than what would be needed.
    225x.40 = 90 side wall +15 mm should have been equivalent to chains 195mm tread and 105mm side wall (7.5mm longer on each side wall)
    In both cases I could not get the chains secured.
    otatrant and Mendel Leisk like this.
  11. I Throw 99
    I Throw 99 Junior Member
    28
    2023 Prius
    XLE AWD-e
    In most states (maybe all), you can also use autosocks instead of chains. The actual 19” wheel size will not show up on any autosock package, but if you enter the actual tire size on their website, it will direct you to the correct size to buy. I bought a set (just have to have them IN my car to pass chain check in CA), and actually put them on to make sure they fit, which they did. It IS a pain in the rump to do though, due to low clearance in the wheel well. Chains would probably be even harder.
    otatrant likes this.
  12. PandaBOT
    PandaBOT New Member
    Colorado
    2023 Prius
    XLE AWD-e
    Did you switch to 17" tires already? I'm looking at doing the same for a 2023 AWD XLE and not sure which wheels and tires to get - any advice would be spectacular!
  13. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I did. I went with MSW Wheels Type 42 from Discount Tire. I initially put Michelin XIce on them and now I have Michelin CrossClimate.
  14. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    Came across Konig K-Summit K44 chains and they say it fits the 2023/2024 Prius 195/50R19 wheel and tire. Brand Tesla accesory shop uses for Model 3.
  15. Beach Dweller
    Beach Dweller Junior Member
    46
    28
    The Beach
    2024 Prius Prime
    XSE Premium
    During the winter here, I don’t make any changes to my tires. I sometimes put on long pants though. It stays pretty warm at the beach.
  16. Prius_KU
    Prius_KU New Member
    Washington
    2024 Prius Prime
    XSE
    I was so happy to see a set of tire chain that would work for the tire, but they are $400.. i see some review stating it just slips off, or plastic piece breaking... I'm wondering if anyone gave them a try on Prius Prime...
