Challenge: Guessing mileage based on oil color
Discussion in 'Gen 2 Prius Technical Discussion' started by AllenZ, Jan 8, 2012.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    That's a good point.
    Question: The amount of oil need to add should vary with the top speed I drive, right? I imagine if I drive modestly and mostly on local, in which case engine runs about 30-50% of time, then the oil temperature will be lower and supposedly burning less oil?
  2. AllenZ
    640
    63
    Chicago
    Not yet. But do you foresee that to happen? The show stopper is obviously someday it can not pass emission test.
    I am going to add some fuel cleaning additive to next 5 tanks. Which one you recommend? I will monitor the oil burning situation closely and report back the result.
  3. Patrick Wong
    18,210
    6,510
    If you need to use an additive then I would suggest Chevron Techron. However if you do not notice engine misfire then the additive probably is unnecessary.
    I would say that your engine is far from the point where it would emit visible emissions, or not pass an emissions test.
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    That's been my experience with cars that used oil in the past. I always noticed the consumption to get worse when driving at fast freeway speeds compared with around town. I think however that the amount to which this matters depends on the exact manner in which the engine is using oil.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    If you do the maths, then in 2000 miles you're probably using about what, 45 gallons of gas? So one qt in 45 gal is somewhere around a 200:1 mix, so you're not quite at a two stroke mixture yet. :D But that (two stroke like ratios) is the territory that you really want to avoid in my opinion.
    I still think it's a valid to manage consumption to some extent with choice of oil viscosity. Old engines have bigger clearances anyway, so why not. I don't mean going overboard and using 20W50 or anything, but if it were mine I'd stick with 5W30 (perhaps 0W30 for winter) and if I was worried about extra wear at start up in winter (due to slower oil circulation) then I'd add 1/2 a can of LubroMoly MoS2 each change.
