Change Aux input for 2008 Prius Touring model inside the console
Discussion in 'Gen 2 Prius Audio and Electronics' started by Giri, Mar 11, 2019.
  1. Giri
    Giri New Member
    Friends
    Below is the issue and need your help.
    The bluetooth of 2008 Prius recognises only telephone and not Phone audio like music. Hence I connect the phone to the aux input in the center console to play music from phone. When I connect the phone via the Aux input the music is not playing.
    I tried changing Aux cables and looks like the fault is not in phone or in aux cables. So narrowing it down to Aux input in center console as a first step.
    Does anyone have any images or youtube videos to access the Aux input and remove the part item.
    It will be helpful as a DIY else I need to take to shop.
    Since the clip is easy to remove thought someone might have photos or videos of removing the aux input
    Toyota Prius 2008
    Touring model
    Toyota 86190-02010 Auxiliary Jack Adapter OEM Quality
  2. Robert D Brown
    Robert D Brown Junior Member
    Tacoma, WA
    I'm having the same issue in my 2008. Does this Aux jack work? I'm trying to play Pandora on my note 9 phone through the aux jack.
  3. mathewjg
    mathewjg Member
    77
    45
    It definitely works on my T-spirit. Make sure the volume is up full on your phone as they sometimes reset to zero when plugging into headphones or aux input
  4. Robert D Brown
    Tacoma, WA
    Bought
    Bought this aux jack, plug is different, didn't work!
Loading...
