Change tires w/43k for road trip?
Discussion in 'Gen 4 Prius Main Forum' started by Shameless, May 28, 2021.
  1. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    That depends on the nature of the trip and timing. I replaced tires shortly before heading out to Wyoming for Thanksgiving. That crossing of South Dakota with potential for snow & ice was best served by new tread.
    If it was still Summer, those aged tires would have been fine. But the possibility of hitting winter conditions and discounts from Fall tire sales made it a wise decision to replace. After all, I would have needed to do it later during the Winter here in Minnesota anyway.
  2. privilege
    privilege Active Member
    659
    169
    Birmingham
    I'm in the woods a lot, and find old dumps regularly. the tires (and wheels) are sometimes very similar to these pictured old Firestones, Google says it's from around 1929. the condition looks similar on those tires to what I'm describing on modern tires. I don't know what else to call it besides dry rot... I'll have to grab some pictures next time I'm by the glass dump.... there are tons of old gin bottles and tires..
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    It is cracking due to age and heat......and sometimes cheap construction.
    Real "rot" results in a condition where you can poke the tire with your finger and large pieces of the outer shell FALLS OFF, sometimes turning to powder.
  4. DaveSC
    DaveSC Junior Member
    Dalzell, SC
    2019 Prius
    I found a donut spare in brand new condition on EBay for about $100 shipped to my home. I removed all the styrofoam cutouts and used soft packing foam to fill in the voids, then just a few well formed bathtowels to wrap up the tools, jack, etc. Works great for minimal cost and now I don't have to worry about that tire inflator goop.
    pilotgrrl likes this.
  5. Mendel Leisk
    41,328
    Checked up on the latest from Toyota.com (US site): for Prius model year 2022, there's ONE level, the base level no less, that comes with a temp spare. Just nuts...
    Doesn't seem like they're exactly proud of it: "Temporary" sounds more lowly than "Tire repair kit". :rolleyes:
    Merkey likes this.
  6. Mendel Leisk
    41,328
    As long as I'm on a roll, this is Toyota.ca, the Canadian site, screen grab from the website:
    Link:
    2022 Prius Specifications - Toyota Canada
    And this is flat-out goofy: says ALL levels get a temp spare AND a tire repair kit. I actually emailed them about that, and got a response, basically saying they couldn't see anything wrong with that page...
    The pdf brochure isn't much help: for the base Prius, the "exterior" section of the spec page says nothing, neither temporary spare nor "tire repair kit". All the other levels DO say "tire repair kit", so reading between the lines I suspect the base still has a spare.
    @Tideland Prius ?
  7. Tideland Prius
    16,548
    Pretty sure it's just the base model. I suspect the new person updates the page and in the past, errors would be fixed. However, I am noticing more errors now on the specification webpages (not just Prius) compared to previous years so either the current person(s) isn't properly briefed/trained or doesn't care enough to verify the specs.
  8. Mendel Leisk
    41,328
    Someone’s getting paid above their skill level, when they’re fine with a web page saying all levels have both systems.
