change trans axle fluid 05 prius
Discussion in 'Gen 2 Prius Main Forum' started by jtuchol, Jun 5, 2013.
  1. jtuchol
    jtuchol Member
    141
    whitehouse,ohio 43571
    I recentily bought a 05 prius with 153k on the speedo I asked the dealer about if fluid should be changed out, they said they have never done one, what should I do and if I do it how?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    At 153k I would definitely get the transaxle fluid changed. Do you have another dealer close by that you could call and ask? Their initial comment is probably going to be that Toyota does not recommend this but if you push they should be able to give you a price for doing this. Most on here have been quoted somewhere around $100 for this service.
    It is a drain and fill for your transaxle and really very simple. If they quote you a flush or talk about controlling temperatures with Techstream they do not know what they are talking about. Find another dealer.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    At 153K your due for
    Trans fluid
    Inverter Coolant change
    Engine Coolant change
    All have been discussed here thousands of times so search as you can do it yourself pretty easily.
    Lots of threads about about how to do it.
    jdcollins5 likes this.
  4. jtuchol
    jtuchol Member
    141
    ok one other thing I noticed about this car was another cv axle in the trunk looks like some one ran this off of the road and in a ditch or something the under side is full of mud and twigs not sure if fluid was lost or replaced or what ever
