Changed 12v Batt
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prynce, May 11, 2020.
  1. Prynce
    Prynce Junior Member
    Winnipeg
    Hi I recently changed my 12 v battery in my 2006 Prius, after changing the battery I tried turning the car on... light turns green and when I press it again it turns orange and the brake becomes difficult to press with the check engine light on!
    49,479
    check the connections for cleanliness and tightness, also negative to ground. if that doesn't help, get a voltmeter and check the battery voltage at the posts. if it's less than 12.7, take it back to be charged or buy a charger.
    if it still doesn't work, check the voltage at the front jump point. if it's close to the same as the battery, you're gonna have to have the trouble codes read
    Stevewoods likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    After a battery change the first attempt[t at starting will light up the dashboard. Wait a bit and try it again it should be fine.
