Changed 12V in 2006 Prius, now it won't move
Discussion in 'Gen 2 Prius Main Forum' started by breetz, Jun 5, 2017.
  1. breetz
    breetz New Member
    Wisconsin
    Just changed the 12V battery today. Less than an hour ago. Everything turns on and everything is normal. Except. When you put it in drive and press the accelerator, you can feel it try to move forward, but the brakes are engaged. Even in neutral the car won't move. Pressing the brake does nothing. Maintenance required light is on. What did I do wrong.
    51,155
    did you apply the parking brake?
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    "Ready"light? …in "Neutral" I don't think it's supposed to move, in fact I'd be more worried if it did move!!! hope this helps (…but need more information!) - Wil :(
  4. breetz
    breetz New Member
    Wisconsin
    It has been sitting parked for about four months. Parking brake was engaged the whole time. I've put it on and taken it off multiple time since and it still won't move.
  5. breetz
    breetz New Member
    Wisconsin
    Ready light is on. I know it shouldn't move in neutral, but I thought you should still be able to push it in neutral?
  6. WilDavis
    2,493
    2,154
    49
    Parking brake "froze" on - well, it has happened to me before! Turn everything OFF and try to rock the brake free? Well, it might just work, else it's a "time to service the brakes" scenario! …sorry! :( …but welcome to PriusChat! - Good luck!!!
  7. bisco
    51,155
    jack it up and try to spin the rear wheels.
    does the engine start?
    WilDavis likes this.
  8. breetz
    breetz New Member
    Wisconsin
    Rock it "free" when it is on or off?
  9. breetz
    breetz New Member
    Wisconsin
    Yes, engine starts. I can feel that the rear wheels are what is keeping it from moving. It jerks forward like it wants to drive, but stops.
  10. WilDavis
    2,493
    2,154
    49
    Sounds like the rear brakes are stuck! @bisco's suggestion is good (but take care with that jack, and use axle-stands if you're able - and chock the fronts!)
    Raytheeagle and bisco like this.
  11. bisco
    51,155
    to rock it free, you want to be in neutral. be safe, with some curb stops in front and back.
