Changed HV battery in 2001 Prius
Discussion in 'Generation 1 Prius Discussion' started by Pgoodyear, Mar 5, 2019.
  1. Pgoodyear
    Pgoodyear Junior Member
    Los Osos, California
    2001 Prius
    I
    I changed the battery on my son's 2001 prius. It had been changed 3 years prior with a rebuilt battery, the vent hose out of the cab was not installed. I obtained a rebuilt assembly from a shop in the LA area. the change out took about 3 hours total. I pulled the old battery, tested the cells, had 3 cells that would not hold a charge, and all of the straps were heavily corroded. I felt the best option was replacement with a 1.5 gen rebuilt. I think the cost was around $800 + 8 hours of driving an d $60 in fuel. No one close had a gen 1 battery. As I understand it the later gen battery (complete) will not bolt into the gen 1 compartment, as it was the new battery was slightly larger than the old battery, about 1/2 in. in each direction.
  2. John Oliver
    John Oliver New Member
    missouri
    2001 Prius
    and so what did you do? did you figure out a way to bolt it in there anyway? i may be doing this same job sometime into the future.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Not clear what you mean by "later gen battery"?
    Do you mean the Gen 2 modules? Yes the modules are slightly longer.
    Or do you mean the length of the entire case of the pack is longer?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    If you used Gen 1.5 modules (gen 1 modules manufactured after 2003 or 2010? idk..) and the battery wasn't exactly identical in size, then something is wrong. If Gen 2 modules were used, then as mentioned before those modules are slightly longer than Gen 1s, but the mounting holes still line up on the bottom, and the thickness is identical, so the actual 38 module packs should fit in the case normally, lengthwise, but there should be slightly less clearance on the sides between the terminal covers and the sides of the steel cover.
  5. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Congrats and welcome to Chat. My understanding of the 1.5 modules is that they are just improved but not a different size from the 1.0. And they are going to be newer than the originals. My 02 has a new battery, circa 2013, but I'm not going out and take it apart to check it.
    Sounds like you did really well on the cost. I guess I would get the Prolong kit to periodically maintain the battery. And don't let the car sit--not using the battery is the way to lose it.
    Where did you get the replacement battery?
  6. Krisstroll
    Krisstroll New Member
    France
    Sorry if i am in the wrong discussion
    hello everybody , I m new on the forum, back in Europe (France) , and not much of people who knows something about working on a prius here, i am trying to solve a pbm :
    prius 2 ; august 2006 ; 192000 KM , used when bought , Tranny maintenance ? 12 V battery fully charged every time i try to start but used
    i had a HT battery failure, bill from toyota that i refused (2500 €), i change my self the 2 faulty elements (thanks you tube) and put back everything : 212 V on testing
    when i brought my prius 2 back home the thermic was working D & R but of course electric was not working.
    since then , and I checked and rechecked everything, the orange big security plug position (as mentioned by several personns) all the 3 connectors to the ECU, the connector to the Fan , even the polarity of the HT connectors ....
    same old song : THE READY MODE DOESN T COME ON, NO D OR R POSITION POSSIBILITY, THE THERMIC DOESN T FIRE UP , I noticed that i don't hear the Clac Clac of relays ans that the 12 V battery is drained after 1 day if stays connected. NO error CODE on ODB device
    i desinstalled one of the 2 main relay to try to test it, but i am stucked
    any ideas ? any suggestions, HEEEEEELP PLEAAASSSE
    thanks
