Changed inverter coolant pump - now nothing
Discussion in 'Gen 2 Prius Technical Discussion' started by Richard Finley, Oct 13, 2021.
  1. Richard Finley
    Richard Finley New Member
    Waco, Tx
    2009 Prius with 127,000 miles on it. My daughter was driving it and the red triangle, brake system light, vsc light, and check engine light all came on. She was close to home, so she drove it home. She checked for turbulance in the inverter coolant when it was running and saw none. I drove it on the trailer and took it home. Drove it into the shop, changed the pump and tried to start it. All I get now is the hybrid system warning light flashing. I cannot get it to stop flashing. I disconnected the 12V battery for a few minutes - still no start and same light flashing. I have no idea what to try next. Need help.
  2. Richard Finley
    Waco, Tx
    Never mind ---- Fixed. I let it sit for about 1/2 hour with the battery disconnected and all is well. No lights and runs fine.
    52,889
    well done!(y)
  4. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    The error codes from those warning lights may of been cleared from memory by what you did, but odds are they'll be back soon. Consider keeping one of these in the glove box: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Once you have one you can use Dr. Prius app to check and clear error codes when the warning lights come back on and we can help you figure out best approach to repairs.
