Changed Key-fob batt, how re-pair?
Discussion in 'Gen 3 Prius Main Forum' started by Sundog105, Aug 17, 2020.
  1. Sundog105
    Sundog105 Sundog105
    Roswell NM
    Gen 3 2012 Prius, got low key-fob battery warning, changed it in both my key-fobs, the Lock & Key shop guy explained something about pushing both fob buttons while near the Start button. What is this? I need a better explanation. Drivers Manual is no help.
  2. Siward
    Siward Active Member
    314
    128
    Toronto
    I own a 2012 Prius. I've changed my keyfob battery so many times now and I have never had to do anything extra. Go take the keyfob for a test. It should work just fine.
    Unless you replaced not just the battery but the whole keyfob?
    Prius Maximus and bisco like this.
    52,849
    never heard of such a thing. did the locksmith change the batteries for you?
  4. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Just drive it. I've replaced my fob batteries several times also and never had to do anything but go drive.
  5. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Check that the batteries were not installed upside down...
    Replacing the fob batteries should not affect how the fob operates...
  6. bisco
    52,849
    if it isn't working, make sure the chip didn't fall out
