Changed rear bearing now throwing abs codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ls6ownerwithaprius, Dec 20, 2021.
  1. Ls6ownerwithaprius
    Ls6ownerwithaprius New Member
    Savannah
    I changed my rear passenger wheel bearing... and it was great for a few months. ... being as i live in Tennessee and the roads are awful... one nite i hit a pothole and my abs lights and the traction light came on. I lost cruise control and regen braking is working but barely. Jus stumped as to what might have broken
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Probably a non compatible bearing or bad connection
  3. ChapmanF
    15,561
    Can you post the trouble codes yet? That will help us offer better suggestions.
    If you haven't got a scan tool to read the trouble codes, all it takes is to turn the car on with a wire between Tc and CG at the diag port, and count the light blinks, which can be looked up.
    Ls6ownerwithaprius likes this.
  4. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    If the ABS connector comes off the wheel speed sensor on the back of the hub, it will cause an ABS fault.
  5. Ls6ownerwithaprius
    Savannah
    Thanks i will take off the wheel and check the connection.
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,957
    4,709
    Texas Hill Country
    It could be any abs sensor, the master cylinder or pump. I would bet it is not your new bearing and sensor unless it was a $50 knock off. Maybe not even then since it worked for a few months.
  7. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    Did you resolve this? What brand hub did you use? I went "cheap" with trq, as they once
    were a good brand. They are crap! They only lasted a few thousand miles before the noise started.
    I don't think they put any or much grease in them. And the right rear one had an abs sensore go bad.
  8. Ls6ownerwithaprius
    Savannah
    I bought a ebay special ... guess i will have to pull it and get a name brand
  9. Ls6ownerwithaprius
    Savannah
    It functioned perfectly for a few months
    Then the lights came on.. intermittently they would go off.... i ran codes it said rear speed sensor and foreign object but ive checked the connection ... like others im leaning towards it being the off brand bearing
    ASRDogman likes this.
  10. ASRDogman
    6,084
    3,271
    You can find the Timkens on ebay. That's where I got mine.... For a decent price.
    Well, at the time it was, but today????
