Changed spark plugs at 97K
Discussion in 'Gen 3 Prius Main Forum' started by itengineer, Jun 26, 2021.
  1. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Looks like they were shot
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    I have had sparkplugs that looked far worse.
    2R45 likes this.
    52,737
    i hope it isn't the pistons/rings/ egr, that is unusual
  4. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Apparently this is a Corona stain, harmless
    tvpierce likes this.
  5. bisco
    52,737
    yeah, you could have gone the usual 120k no problem
  6. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I swapped mine at the same mileage. They looked almost identical to these. Nothing to worry about.
  7. itengineer
    itengineer Member
    86
    25
    Minneapolis
    I am noticing a noticeable increase in power from the engine.
    Eco mode feels like normal now
    Also less noise from the engine
    varun singh and Montgomery like this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    which plugs did you put in?
  9. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Denso SCHR11
    $20 for 4 on eBay :)
  10. Siward
    Siward Active Member
    314
    128
    Toronto
  11. ChapmanF
    18,917
  12. ETC(SS)
    7,467
    Fake Chinese knockoffs, it looks like.
    Hope I'm wrong, but the price suggests otherwise.
    It's not just fleabay.
    Amazon has a biiiiig problem with fakery too.
    Given how hard they are to get to and how long they (are SUPPOSED to) last this is one of the few times that I would go with dealer stock or one of the big suppliers.
    YMMV
  13. privilege
    privilege Active Member
    659
    169
    Birmingham
  14. ASRDogman
    ASRDogman Senior Member
    8,004
    4,064
    I skipped those problems and bought Bosch...
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    so you’re saying Bosch plugs guarantees that plugs will stay original color under the same oci?
  16. ASRDogman
    8,004
    4,064
    No, counterfeit problems.......
    On the 2nd set. When I pulled the 1st set out I couldn't tell if there was any wear.
    They all get discolored from the heat. But nothing abnormal.
    #16 ASRDogman, Jun 29, 2021
  17. ChapmanF
    18,917
    Yeah, what kind of loser would ever counterfeit Bosch?
  18. itengineer
    itengineer Member
    86
    25
    Minneapolis
    No, these came in just like original with the Denso and Japan inscribed in the metal. Also they came in a toyota lexus box. They alaso had a plastic sleeve on top of the plug to protect the firing element. Quite comfortable that these were original
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    so they’re not original, but just like original o_O
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    your reply was after post #13 and didn’t quote anyone so I believed you replied to post #13 :LOL:
