Changed spark plugs...world of difference
Discussion in 'Gen 3 Prius Main Forum' started by Jeffrimerman, Aug 3, 2021.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Finally did the plugs at 124k miles so not too late. I was dreading the work but watch a 4:20 youtube video so it was pretty quick. Just make sure you have a deep socket 14mm and lucky a neighbor had one. Drives much much smoother and my mileage jumped. My old plugs didn't looked fouled. I would have done it at 100k but all the posts I read seemed like it didn't make much of a difference. I only drove a couple miles so lets see after 1000 miles. I used NGK Laser Iridium ILKAR7BII 4912. I think the rust looking stuff on the plugs was anti seize.
    Paul E. Highway, Merkey and bisco like this.
    52,763
    power of positive thinking :cool:
    Grit and Johnny Cakes like this.
  3. Mendel Leisk
    42,251
    Don’t take it the wrong way; just cheap insurance: hang onto the old plugs for a while.
    Grit likes this.
  4. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Yeah I usually do that to make sure. As soon as it started up it was smoother and more quiet. I could tell when the engine would crank up it seemed slightly rough so one plug was probably fouling ish. I'll report back with my positive thinking ;)
  5. bisco
    52,763
    btw, the plug change interval is 120k
    Grit and Jeffrimerman like this.
  6. Mendel Leisk
    42,251
    He was just fashionably late.
    bisco and Jeffrimerman like this.
  7. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Correct, so I purchased them when I hit 110k and finally had a day I could do it.
  8. bisco
    52,763
    gotcha. your mention of 100k made me think that you thought that was the interval
    Mendel Leisk and Jeffrimerman like this.
  9. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Yeah, I just meant if I'd known my engine was running rough because of plugs I would have changed sooner. Since I'll never change them ever ever again and they aren't expensive then couldn't hurt to change them a little sooner. I'll report back so we know if it was indeed the plugs
  10. bisco
    52,763
    have you done the egr?
  11. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    No, I better google to check it out. I see a youtube covering cleaning out the egr pipe. Maybe that's some good preventative maintenance.
  12. Mendel Leisk
    42,251
    EGR info in my signature.
    Jeffrimerman likes this.
  13. Merkey
    Merkey Active Member
    327
    298
    Birmingham, Michigan
    I had the same results with plug change @ 120K.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  15. ChapmanF
    18,947
    Did you happen to jot down the ECM data list "misfire margin" from before and after the plug change?
  16. Merkey
    327
    298
    No I didn't. Not sure how to even do that.
  17. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Good job! I have everything ready (new Denso plugs, new manifold gaskets, new throttle body gasket, etc) to change out the plugs on my daughters 2012 Sienna...have to remove a bunch of stuff to get to those three plugs on bank 1 so will take me a few hours. Going to also clean up her throttle body since I'll be in there. Those plastic electrical connectors on the coils are the scariest part...the small plastic tabs get old and brittle and have been known to break so I use a small pry tool to gently lift up on one end while pushing down on the other end with my finger to remove.
    But the hardest part with maintaining my daughters' vehicles are actually getting my hands on them for a few hours...they are very busy people!
  18. Mendel Leisk
    42,251
    Oh lord, you need to remove intake manifold? It’s a V right?
    I hear you: I’ve been just wrapping oil change and tire rotation on our daughters (ex) Pilot, struggling with behemoth wheels, while she’s tapping a toe, late for “something”. I think I didn’t mix them up.
  19. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Yep, she has the V-6 with AWD. So I have to remove the wipers, plastic cowl, metal cowl, air manifold, throttle body, and all the connectors/hoses to such. I'm looking forward to it, actually! He van needs just about everything so I'm trying to get my hands on it (fluid changes on front/rear diffs, transmission, transaxle, oil change) And she just told me her brakes are making noises....ARGH
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
