Changed the White China Plastic
Discussion in 'Prime Accessories and Modifications' started by DavePrimeAdvanced, Jan 29, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    Looks good, did you do it in place or remove it from the car?
  2. Michael Leary
    Michael Leary Junior Member
    39
    22
    Kansas, U.S.
    I used some of the fiber wrap in my cup holder. Looks good, yours look better,
  3. Krypto
    Krypto Junior Member
    Rhode Island
    That looks fantastic! I don't get the appeal of the white accents either.
  4. DavePrimeAdvanced
    DavePrimeAdvanced New Member
    New Jersey
    How did you remove the cup holder area? Did you require a trim removal tool?
  5. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    Yes and no. These make life easier and help reduce the use of expletives.
    Take the vertical piece at the back off first. I broke the top center tang.
    Pull up with the 2 slots at the aft edge
    Disconnect the electrical connectors and release the ty-rap standoffs, one couldn't be released so I used a small pick to release the ty-rap.
    Once free, 6 screws hold the bottom of the cup holders to the console assembly.
    I can lift the bottom edge of the steering wheel piece but haven't figured out how to fish it out without removing the airbag/horn button.
  6. Prodigyplace
    12,697
    11,840
    Central Virginia
    Perhaps @Elektroingenieur can drop a couple of hints.
  7. DavePrimeAdvanced
    New Jersey
    Thank you for all the informative pictures and descriptions, this is really helpful!
    The hardest part for me is getting a grip on the top part and I'm afraid of using too much force to break it. I'll try again, if can't get a good grip on it will go buy the trim remover tools.
  8. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    Hi op, was the parts from ebay came painted gloss black or its just matte unpainted black?
  9. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    i doubt you can remove the bottom trim just by pulling it ...
    as you can see in the picture , the bottom trim and the control assembly is screwed together from behind . i see two screw on the top of the white piece.
    #29 Flaming, Feb 7, 2018
    Prodigyplace likes this.
  10. Elektroingenieur
    2,515
    3,287
    Three Touring
    @Flaming is correct; the steering pad switch assembly is held in place with two screws. To remove it, the horn button assembly must be removed first, while taking care to follow the airbag system precautions stated in the Repair Manual, available by subscription to techinfo.toyota.com.
  11. DavePrimeAdvanced
    New Jersey
    It was painted gloss black.
    I found it much easier to just buy the applique and wrap that instead. Easier to remove in the future as well if needed.
    Skapruisprime likes this.
  12. SR-71
    SR-71 Member
    98
    108
    NC
    I just did my steering wheel. I purchased black cover from eBay. It took nearly 2 months to receive it from China. I had pretty much given up hope it would arrive. Gloss black is better than a toilet bowl white, but a flat black color would have matched the wheel better.
  13. Prodigyplace
    12,697
    11,840
    Central Virginia
  14. Mendel Leisk
    42,040
    Gloss in any colour is going to show fingerprints, scratches. If you're into old-school photography, it's akin to a condenser enlarger: mercilessly showing every scratch and dust speck.
    Dark grey, matt, with a texture, is where it's at. Toyota mis-stepped here. The car's interior in the spy shots, with everything draped, looked better, lol.
    padroo likes this.
  15. Prodigyplace
    12,697
    11,840
    Central Virginia
    My console is matte black so there are some reasonable options Still some gloss black trim on the dash though.
  16. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    It's never too late to pull it off and hit it with some plastidip and see if you like it better that way.
    Sezy likes this.
  17. CrunchTime
    CrunchTime Junior Member
  18. My first EV
    My first EV Junior Member
    38
    16
    2018 Prius Prime
    That’s exactly what I want to do! I hate that white part—-totally not in tune with the rest in the area!
  19. evphreak
    evphreak Junior Member
    Colorado Springs
    2018 Prius Prime
    I tried wrapping the white plastic around the shifter. Does not look good at the corners. Any tips? Yours looks very professional. Well done!
