changing air filter
Discussion in 'Gen 2 Prius Main Forum' started by echeng66, Sep 11, 2008.
  1. echeng66
    echeng66 Junior Member
    Michigan
    My car is due for an oil change (15,000 miles). When I took it in for an oil change last time, the dealer recommended a cabin air filter change. He said it's in the manual, I showed him the manual said change it at 30,000. He told me they always recommend the change at 10,000. I know that many of you change you own filter but I am not very handy so I am not going to change it myself as I will probably break something. So what is your advice, should I change it at 15,000 or wait until 30,000.
    Thanks.
    Ed.
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    at the really low prices that the toyota air filters sell on the web, you could change them anytime you feel like, its pretty easy to do it yourself.
    don't let the toyota dealer change it, he is probably going to charge you $69.95 to do it.
    you should at least open the filter compartment once in a while , and take a look at the filter and see if its good, and shake it out, remove large debris, and maybe even vacuum it or blow air at it a little
    i don't understand how they justify $69.95 for a $19 part and 30 seconds of labor. maybe toyota cabin filters on all the other toyotas are more difficult or time consuming to change
  3. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    It really depends on the envrionment you live in. It's very simple to check and change.
  4. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    It will surprise you how dirty it will be even at 15,000 miles, it wouldn't be a bad idea to pull it out and shake out all the dirt and leaves that get on it. Or if you could also just pay $10 - $15 for one at your local autoparts or wal-mart and change it yourself. Even if you aren't handy you would not have a hard time changing your cabin air filter yourself, its as easy as changing batteries in a TV remote. If you open up your lower glove box there is a little strut like connecter that opens and closes the glove box. Carefully pop it out Then if you look straight in you will see the holder for the air filter. Pull top straight out, clean or put new filter in, push back in the slot, lift glove box up and pop the strut thing back in. If you have any problems doing this the guys at an autoparts store like Autozone will probably be more then happy to give you a hand with this for free.
  5. rigormortis
    1,340
    26
    san jose, ca
    btw
    the only two things you have to be careful about when changing the cabin air filter tray are:
    1) do not drop the contents of your glovebox, you will have to pick them up later, haha
    2) do not drop the tray, if you drop the tray and a clip breaks, it will cost at least $10.42 for a new one
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Personally, I like to tap-out and vacuum the cabin A/F every 10K,
    and replace it at 30K. The simple procedure is covered on p.300-302 in your owners manual.
    The engine A/F is the one I like to replace at 15K intervals. Although also required at 30K, I like to keep my engine breathing clean and easy.
    Plus, it's even simpler than the cabin A/F.
    If someone walked up and handed you $75.00 cash, with a smile, and walked away....How would you feel?
    That's the way you'll feel when you do these items yourself, cause that's how much you kept in your pocked and out of the dealers.
    That's two tanks of gas.
  7. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I am looking for a comparable FRAM cabin filter or perhaps a Purolator cabin filter. Does anyone know what are the part numbers?:confused:
  8. rigormortis
    1,340
    26
    san jose, ca
    purolator
    C35516
    fram
    CF10132
    man those are more expensive then what toyota charges, i wonder if its worth the money
  9. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Change it when it gets dirty. Mine gets full of bees, bugs, dirt and debris way before 30,000. I check it every 5K when I do the oil. It takes 2 minutes, and is so easy to change, why waste money paying a dealer, scheduling it, waiting for it, etc. ??? Better yet, it is washable, so I have two, and wash it out and alternate each time it looks dirty. its no big deal...really.
  10. hyo silver
    hyo silver Awaaaaay
    15,260
    1,599
    off into the sunset
    The cabin filter really is pretty easy to get at once you've got the hang of it. I check mine every time I wash the car and at least shake the debris out. Having taken good care of it with frequent vacuuming and washing, I only recently replaced the original after 50,000 km.
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    If your lucky and have a decent dealer ask him if he charges laor to change it or just the part. My dealer doesn't charge labor for things like air filter, wiper blades, ect. The cabin airfilter, like other people said, gets dirty way before 30k. Also don't forget the engine intake air filter. I usually change it around 15k.
  12. echeng66
    Michigan
    Thanks for the responses.
    Ed.
  13. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Remember to squeeze the sides of the lower glove box inward to
    release those little catch-points as you're lowering it before
    unclipping from the rail, too...
    _H*
  14. morpheusx
    1,555
    81
    Akron, OH
    Oh yes, I forgot about those. By the way I picked up my Fram Cabin Air Filter at a wal-mart for about $13 and I was really happy with the way it was constructed.
  15. rigormortis
    1,340
    26
    san jose, ca
    how long does it take to air dry after you wash it?
  16. echeng66
    Michigan
    I would like to thank again for everyone who responded. I went in for the oil change and tire rotation. Luckily, I received a coupon for free checkup that includes checking the cabin filter and engine filter. They checked them and told me that they are o.k.
    Thanks again.
    Ed.
  17. subarutoo
    1,213
    23
    Chatsworth, CA
    I hosed it out, and hung it in the patio and forgot about it for a couple of days. In hot dry LA, it shouldn't take more than an hour to dry. I have two, and just alternate them, so I don't really wait for it to dry before putting it back.
