changing cabin filter -- I SWEAR, I checked several places already??
Discussion in 'Gen 2 Prius Main Forum' started by cyberprius, Mar 4, 2008.
  1. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Seeing this thread slow down has been disappointing. Can we all send cyberprius some wine (and cheese for the mice) to get things started again?
    :D
  2. moprius
    moprius New Member
    Missouri
    2001 Prius
    I have a different, possibly less entertaining, problem with changing the cabin air filter. I foolishly had the local dealership do this task, and they broke the glove box door clean off. They said it was jammed and wouldn't come off and the filter really needed changing. It's the 2 plastic clips on the back that are broken and the dampener thingie on the side is gone.
    They offered to install a new one for me, but I'd have to buy the assembly for over $100. No, thanks.
    Has anyone else had a similar problem, and does anyone know of any source for the glove box assembly *other than* the local dealership? I'm planning to try junkyards - who knows?!
  3. dogfriend
    7,512
    1,191
    Carmichael, CA
    Let me understand this:
    You asked them to change the filter, they broke a part on your car and now they want you to pay for the broken part?
    :doh:
    I would request that they fix the part they broke. If they don't, then I would call Toyota Customer Service and request they fix the part the dealer broke.
    They broke it, they should fix it.
  4. hill
    9,041
    You have an '01 ?!? Hey there ol timer. That happened to me back in '04. I don't even think they're (Gen I vs Gen II) the same, are they? The dealer broke ours under warranty so they ate it. You'd do better price wise, to check with salvage yards.
  5. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I agree with dogfriend. There's two clips, and the suspension/dampener-thingy on the right that slides off. If you don't do these relatively easy things, you can break it if you force it. Sounds like they didn't know what they were doing and forced it. Strongly. You shouldn't pay for their incompetence.
  6. moprius
    moprius New Member
    Missouri
    2001 Prius
    Yup, it is an '01 - been to Alaska and back, creeping up to 95K miles, with very few problems.
    And yes, I agree that the dealership should replace the part - I'm resuming that battle with them, but, to be fair, when they had the car in the shop, they called and told me the glove box door seemed to be jammed and wouldn't come off properly, said the filter really needed to be changed, and they might have to break it to get it off (the glove box had never acted jammed in normal operation). I stupidly said they should do what they needed to get the job done, partly because I was in shock at some other, unrelated car news they had for me that I won't go into here! I had not yet discovered John's website with the fantastic description of how to change the AC filter, or I would have tried doing the whole job myself.
    So, I'll keep trying salvage yards.
  7. moprius
    moprius New Member
    Missouri
    2001 Prius
    Sounds good - not hearing anybody else with a similar problem makes me feel more justified in complaining louder to the dealer.
    Thanks for the input. And I will never take a car in for service again without learning everything I can about the issue beforehand!
  8. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    How did they know it needed to be changed if they couldn't get the glove box door off to inspect it? It's not like there's a "cabin filter change required" light on the dash.
  9. hill
    9,041
    Maybe the Gen I has a tiny glass observation window :D
  10. moprius
    moprius New Member
    Missouri
    2001 Prius
    They said they got the glove door moved enough to peer behind it and see debris caught around the filter.
  11. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    :confused:They are nuts. End of story. Even if you could get the glovebox moved far enough to see behind it, there is no way to see past the cover for the filter.
    If they broke it, they should pay for it. Polite persistance.
