Changing Coolant questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Mar 8, 2023.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Two questions
    I forgot to get a new gasket for the inverter drain plug Will that be a problem?
    Is it hard to put the car into maintenance mode?
    Thanks
  2. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    First Q.: Probably not, if it's undamaged. Odds of success are better if you keep the same side up.
    Second Q.: Not if you have the instructions for that dance and aren't too slow.
    Doug McC, Paladain55 and Taxi/Limo like this.
  3. Taxi/Limo
    524
    107
    Putting it in maintenance mode was easy and I did not have to rush
    I did not need to rush through the mainteance mode steps I took my time
    This guy helped make it easy
