Changing CVT fluid today
Discussion in 'Gen 2 Prius Main Forum' started by George W, Nov 19, 2019.
  1. George W
    George W Senior Member
    934
    519
    San Antonio
    Leaving on a trip tomorrow. Changing transmission fluid today.
    See the old fluid, the new fluid going in, and the old drain plug gunk.
    #1 George W, Nov 19, 2019
    ydpplqbd and PriusCamper like this.
  2. ydpplqbd
    ydpplqbd Active Member
    551
    254
    How many miles do you have?
    SFO likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I've done this many times......do it again when you get back..... and you can use Valvoline Synthetic WS rated...works fine or Redline
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Why would he need to do that?
    Raytheeagle and Mendel Leisk like this.
  5. George W
    934
    519
    San Antonio
    165K
  6. Mendel Leisk
    42,215
    QUOTE="George W, post: 2968950, member: 162763"]and the old drain plug gunk.[/QUOTE]
    2nd gen drain bolt is magnetic? It ticks me off that 3rd gen isn't.
    First change?
  7. George W
    934
    519
    San Antonio
    It is my first change. I purchased the car at 125K.
  8. Mendel Leisk
    42,215
    Might be the original fluid...
    padroo likes this.
  9. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    To clean out the trani......you never get all of the fluid out......especially if he plans on keeping it for another 100,000.
    It's cheap and easy.........lowest cost and easiest thing you can do to a prius....
    Georgios likes this.
  10. Mendel Leisk
    42,215
    I don't understand why an alternate fluid would flush things out any better. The drain is something like 90%.
    And Toyota's pretty adamant to use only the Toyota ATF WS fluid. I know about your science experiment lol, but I would stick with the OEM fluid, for a transaxle in good working order.
    Data Daedalus likes this.
  11. George W
    934
    519
    San Antonio
    First change?[/QUOTE]
    I was a little surprised that the plug is magnetic.
  12. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Valvoline is WS..... plus my Honda says to use only honda oil or may cause damage...never have run honda oil...just mobile 1
    Look at his drain plug....the rest of the trani looks like that....
    Toyota WS is nothing special...... I had this discussion at OIL Com (massive trade show) in Houston. I don't believe much that any automotive manufacturer says about use their fluids only. And I didn't mean he had to use a different fluid..... but I understand your comment.
    #12 Tim Jones, Nov 19, 2019
    edthefox5 likes this.
  13. Mendel Leisk
    42,215
    Toyota only takes this adamant stance with the transaxle fluid. Their the coolant spec is a close runner up, but they do acknowledge other coolants will work, if (and there's a long list of provisos).
    Motor oil, they just name a spec. And I'm not sure how this came up, but I've had Hondas for decades, and I've never seen an adamant stipulation from Honda that you must use their brand of oil. FWIW, I'm using Toyota bulk oil in a couple of Hondas, lol.
    Getting back to Toyota and their ATF WS fluid: when they tell me, and it's just this one fluid (which they seem to think is lifetime too, so I don't see them getting rich over this), when they tell me using anything else could damage the transaxle, I'm just bright enough to go along with it, lol.
  14. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    That's on my honda GL1800 and GL1500
    #14 Tim Jones, Nov 19, 2019
  15. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
  16. Mendel Leisk
    42,215
  17. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    So..every time you do an oil change, you do it again 500 miles later?
    Tim Jones likes this.
  18. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    No... because the oil hasn't been in there 125,000 miles.....but I do change every 4,000 : )
    I was born in the mid 50's..... been working on cars since I was 12 years old..... rebuilding engines and tranis at 14.......
    #18 Tim Jones, Nov 19, 2019
  19. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Once it gets to this, I surrender...
    next it'll be...I've got more time sitting on the crapper at test depth than you have at...(something something and something else).....
    @ETC(SS) should like that one....
    edthefox5, Mendel Leisk and ETC(SS) like this.
  20. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    That was uncalled for......... I'm just trying to help....... I could say more but I can control my rudeness.........
