Changing dashboard clock 2017 Prius Prime Advanced
Discussion in 'Prime Main Forum (2017-2022)' started by Bill Samuel, Mar 11, 2018.
Tags:
  1. Bill Samuel
    Bill Samuel Junior Member
    Rockville, Maryland, USA
    Well here in the USA we just went on Daylight Savings Time. Went in to change the clock, and used the manual instructions. That changes the system clock. It's very easy to switch on DST. However, for some unknown reason the dashboard clock is not synchronized. That did not change. There appears to be nothing in the manual about changing that clock. I've seen comments in various forums about this, but none of the suggested answers worked for me. Does anyone know how to change the dashboard clock in the 2017 Prius Prime Advanced?
  2. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
  3. Bill Samuel
    Page 185 is not about the dashboard clock. Those are the instructions I followed to change my clock. It changes the system clock, which is not something normally visible to the user. The dashboard clock is not related at all to the system clock (I'm not sure why - it would help to have just one setting). Changing the system clock has no effect whatsoever on the dashboard clock.
  4. joachimz
    451
    612
    17
    SoCal
    well, I just went through the instructions on pg 185 and it updated the time just fine ...
  5. Tideland Prius
    16,642
    Sure it is
    Raytheeagle and Lucifer like this.
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    It's one of the, good tideland beat me to it.
  7. eluo
    eluo Member
    119
    71
    Commack, NY
    For a vehicle with so much tech, I'm surprised that it doesn't auto update the clock.
    KCWhitney, Rikku and HPrimeAdvanced like this.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    This has been a gripe for years.
    HPrimeAdvanced and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Just be thankful you don’t have a Lexus that has the same issue:cool:.
    HPrimeAdvanced likes this.
  10. albus
    albus New Member
    28
    San Jose, CA
    As stated before, page 185 of the owner’s manual is your friend in order to adjust the (dash) clock. For the sake of completeness in order to handle Daylight Saving Time, one might also refer to page 68 of the Navigation System Owner’s Manual in order to change the system time. I have no idea why there are two clocks though...
    Tideland Prius likes this.
  11. Bill Samuel
    It's very complicated because there is more than one screen which fits the picture designation. It just uses "the" without explaining which one of those screens it is referencing. I finally figured it out. They need a more user-friendly manual.
  12. Tideland Prius
    16,642
    I don't know... maybe it's cause I've owned my Gen 3 for 9 years so it's second nature to me (that even the Prime/Gen 4 works the same way).
    I change the dashboard clock (although with the VFD in the Gen 3, I use the physical H, M and :00 buttons) and then dive into my navigation
    SETUP --> CLOCK --> Daylight Saving Time --> ON.
    So.. I do them both, twice a year for the last 9 years.
    It would be nice if the navigation one auto-updated (esp. since the Gen 4/Primes are connected to the cloud) so one would only have to change the dashboard one.
    illumiN8i, albus and benagi like this.
  13. bwilson4web
    16,472
    So does the dealer’s VCR and microwave clock flash “12:00”?
    Liz Waters and Mark57 like this.
  14. El Dobro
    El Dobro A Member
    7,102
    3,282
    Only when they work.
    benagi, bwilson4web and Raytheeagle like this.
  15. krngee
    krngee New Member
    Finger Lakes, NY
    I can't seem to find the correct screen, either. How did you get to the one that actually controls the dashboard clock?
    Thanks!
  16. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Steering wheel right hand button for the MFD. Scroll up/down until you get to clock.
  17. Bill Samuel
    The reference to the Navigation System Owner's Manual is incorrect. That page is the contents for the Audio portion. Further, I did a search on the PDF, and "clock" is not in the Manual at all. All clock references (including one specific to the system clock) are in the owner's manual and all refer to page 185. The interesting thing is that the symbol referenced there is on 2 entirely different screens in the Prius operation. Apparently you need to go to these entirely different screens to change each clock.
  18. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    I need help on this, too. I successfully changed the dashboard clock, using the multi-information display, but the navigation system didn't change. Its ETA estimates are still on DST. For the life of me, I can't find how to adjust that.
  19. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    Settings
    General
    System Time
    DST OFF
    Come Spring you need to do the reverse.
    Some photos attached for those so inclined.
    #19 schja01, Nov 6, 2018
    illumiN8i likes this.
  20. Bill Samuel
    That's a very easy setting to get to, but I found it wouldn't work. It will not change from ON. When you click on it to change it, it just goes back to the previous screen and doesn't change the setting.
