Changing DATE
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Zimmy 1, Nov 26, 2012.
  1. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    Trying for two days to change the date in my pip advanced. Get as far as calendar adjust mode. Asking for arrows up and down. Then display goes to " temp". Any thoughts????
  2. What is really interesting is that the site is still F/U, does Toyota have any programers that know what they are doing?
  3. Zimmy 1
    61
    Smithtown NY
    I know, my grandson has taken 4 years of Japanese, I will have him try to change the date. I think I am getting very good milage, have 308 miles with a half tank of gas left. Thats over 60/mpg I think.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    what does "Zimmy" stand for?
  5. on the PIP, I believe the long term mpg under Trip B or the short term, Trip A. Assuming no zeroing out on Trip A. I misunderstood perhaps, before. For what are you changing the date?
  6. Edit. Assuming no zeroing out on Trip B.
  7. Strange, I could not edit normally, tried 3 times
  8. You may be holding the buttons too long
  9. Zimmy 1
    61
    Smithtown NY
    The date displays as 2-3-11. Now we know that is not the presnt date, I can't seem to find a way to change it.
    lensovet likes this.
  10. Zimmy 1
    61
    Smithtown NY
    I will try it. Thanks
  11. lensovet
    2,614
    495
    Burlington, NJ
    You can't use the arrows on the steering wheel or by the climate controls to adjust the time.
    If you're trying to adjust the time by the speedo, you keep pressing some button on the steering wheel to increment. I don't remember off the top of my head.
  12. Zimmy 1
    61
    Smithtown NY
    Yea I tried those arrows and they did not work. It has be possible to change the date ( and the time). I will not give up. Today is another day, I will sit in the car and push buttons until it works.
  13. lensovet
    2,614
    495
    Burlington, NJ
    This is described on page 276 of the manual
    if you don't have that handy, it's linked in the FAQ sticky thread
    you press DISP to increase and TRIP to decrease the date. 5 seconds after no operation it automatically saves.
    cheers
  14. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    It is a bit cumbersome, but it does work…….
    1) Using the “Display” button, step to the “Settings” screen (displays the currently saved date)
    2) Press and Hold the Display Button; Display will change to “Settings” menu
    3) In the menu screen (shows “exit/calendar/ev-eco/etc”) press the “Display” button to step through these options
    4) Stop when “Calendar” is highlighted
    5) Press and hold the “Display” button,; screen will change to the currently saved date and show Display and Trip buttons for increase or decrease.
    6) Press either “Display” (increase day) or “Trip” (decrease day) until the correct date is set. Pressing either button will increment the “day” one at a time, or holding the button down will cause the date to scroll faster.
    7) Once the correct date is displayed, wait about 5 seconds and the update will be stored.
    8) You do need to work quickly; if you pause during the setting, it will save and you will need to reenter the menu again to continue
    It does work; I was able to successfully set my calendar.
  15. Zimmy 1
    61
    Smithtown NY
    Thank u very much, I shall try it again in the morning I will let everyone know if it works.
  16. bisbonian
    bisbonian Junior Member
    Thank you! I've been trying to set this calendar for a week now. The owners manual was completely unhelpful.
  17. CicilyMJ
    CicilyMJ New Member
    Vineland, New Jersey
    2013 Prius Plug-in
    Thank you so much! I'm a NOOB and couldn't figure it out no matter how hard I tried!!
  18. Nathen
    Nathen New Member
    2013 Prius Plug-in
    I too needed to set the date -- very strange process but now it is set thanks to the instructions.
    Setting the date will allow your DISP to graph monthly consumption correctly.
    Doesn't take more than a few minutes, pretty easy.
    CicilyMJ likes this.
  19. orracle
    orracle Whaddaya mean "senior" member?
    441
    Gurnee, IL
    I figured out this much--I changed the date okay but I can't get to the year. Since it says 2012 and it's now 2014 I'd really like to fix that!
