Changing Driving Modes
Discussion in 'Gen 3 Prius Technical Discussion' started by pwryan, Apr 19, 2012.
  1. pwryan
    pwryan New Member
    NH
    Is it "safe" (meaning for the car) to change driving modes while driving? I understand that all it really does is change the way the throttle pedal works but just want to make sure that I don't have to be stopped to change modes.
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    It should be OK, as long as you have your seatbelt and G-suit on.:D
  3. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Personally, I leave the Prius in "NORMAL" mode and let the computer choose.
    For me, one of the desirable things about the Prius was that it had an automatic transmission so that I would not have to monkey with "modes".
  4. Tideland Prius
    16,678
    Yep. You can change on-the-fly.
  5. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Something tells me the computer will always choose "Normal" in this case.
  6. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    If you pay close attention, if you change to a more aggressive mapping mode when you are accelerating, it will delay the change until you let up on the throttle. I assume this was done to prevent an unexpected surge in acceleration. I now drive in Power mode most of the time and have noticed this if I forget to hit Power mode when I first hit Ready mode and I change from Normal to Power while accelerating.
    The software protects the hardware. You can hit the Park button while doing 70 MPH and it will beep and drop you into Neutral with no harm done.
  7. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    While I'm sure you are correct, I just cannot bring myself to the point of testing this hypothesis.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I've tested every combination: Park, Reverse, Neutral, and Power. All are safe at speed.
    You really should practice this, as every driver needs to know how to stop in a runaway situation. For the Prius, my method of choice is hitting Park, which causes an immediate shift to Neutral.
    Tom
  9. pwryan
    pwryan New Member
    NH
    Thanks all, both for the comforting answers about switching modes AND for the extra information! Very interesting, though I don't think I'll test it either, unless I need to of course!
