changing fluids and coolants question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by av8erdunn, Jan 3, 2015.
  1. av8erdunn
    av8erdunn Junior Member
    78
    Mobile AL
    I have used the search feature to try to locate a how to thread with pics on changing the inverter and engine coolant and the transmission fluid with no luck. I have found some that would work but they were kinda vague. If someone could point me to the threads it would be great and please tell me if there's a sticky that I'm missing.
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Transaxle fluid and inverter coolant are easy. Basically all you need pictures for is to open correct bolts. Engine coolant is tricky to bleed but pictures don’t help you a lot for bleeding.
    Hobbits 100k maintenance (for example) 100K maint - 4 has all pictures you need to do this job.
  3. prius8654
    prius8654 Junior Member
    What is that bleeder line for that hobbit has in the "4th to last" and "3rd to last" pictures?
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Allowing the inverter pump to push air out of the system, when you allow flow thru the bleed loop to the reservoir, it is much easier to get all the air out.
  5. prius8654
    Ahh, gotcha. Thanks for the response
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Don't the @NutzAboutBolts guys have some videos that show these fluid changes? o_O
    NutzAboutBolts - YouTube
    Haven't watched them myself, and they may be vague.. but I bet the lighting is top notch! (y)
    NutzAboutBolts likes this.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Yeah just search our YouTube channel. Easy pezzy
  8. Mendel Leisk
    42,347
    SFO and Raytheeagle like this.
  9. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Nope :(
  10. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Thats what I keep telling y'll Gen 3ers.
