Changing horn in 2016 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by booke02, Apr 16, 2016.
  1. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    I installed FIAMM horns I got locally through a NAPA store because, for some reason, Amazon had one of the horns marked as "unable to ship to Hawaii".
    The horns in the video are dual tone horns, not just the low tone. The tones blend to make a harmonic sound.
    GoodOldBob likes this.
  2. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    Oh, I get it... so one high and one low.
    I know someone on here (in the Gen 4 section) installed the dual Red ones from the same company. I have to search for that... or maybe they'll chime in (no pun intended).
  3. krmcg
    2,592
    2,393
    Whittier, CA
    The red ones. This is what I installed. One of the two horns has an "L" embossed on it - I put that one on the left. Plug and play swap to the existing two horns.
    GoodOldBob and PriUncut like this.
  4. PriUncut
    268
    266
    Southern California
    Four Touring
    Thank you... that's right... it was you're post I originally saw. I put put those Red one's on my Amazon Wish List. Thanks for the additional "L" & "R" information.
    I assume your red ones sound similar to ones in the video?
  5. krmcg
    2,592
    2,393
    Whittier, CA
    I'm at work - no video allowed
  6. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Do you know the secret of the Toyota clips ?
    What ever you do, do not use a tool on those clips, and mess them up.
    They operate with a finger.
    When flush, they are locked. When you push down, they unlock. When removed the pin can be pushed up, and now they are ready to be locked
    #26 I'mJp, Jul 11, 2016
    krmcg likes this.
  7. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    I boogered a couple of them up because I was taking the piece off in the parking lot of the auto parts store and they told me I couldn't do that and would have to close it up immediately. If I can't fix them I'll see if I can get 2 new ones at the dealer. Didn't get to see where horns are located. That NAPA didn't have the horns mentioned above, will have to try another one tomorrow.
  8. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    Cannot figure out howo get the factory connector on the new horn. Factory is two very small spade clips while 74100 is one much larger clip. If this doesn't make sense I can post pics.
    #28 jbkendrick, Jul 22, 2016
  9. krmcg
    2,592
    2,393
    Whittier, CA
    The blade connector unclips from the factory horns but just slides onto the new horns without need for the clips.
  10. jbkendrick
    232
    197
    Baltimore, MD
    I know I being dense, but the only connection point I see on the new horn is two posts, one of which has a blade connector on it.
  11. krmcg
    2,592
    2,393
    Whittier, CA
    Use the blade. The post with the threads is for attaching the horn to the bracket.
  12. jbkendrick
    232
    197
    Baltimore, MD
    QUOTE="krmcg, post: 2387190, member: 40648"]Use the blade. The post with the threads is for attaching the horn to the bracket.[/QUOTE]
    Let me show some pics, my dilemma might be more understandable. So here is the connector still attached to the cable in the car from which I disconnected the factory horn. Next pic is the 71400 horn and its two posts with a spade connector on one of them. Of course the larger center post is for mounting the horn. Thanks KRMCG for your help, I really appreciate it. J 20160722_191920_resized [3415585].jpg 20160722_183950_resized [3415586].jpg
  13. krmcg
    2,592
    2,393
    Whittier, CA
    My iPad won't load your attachments
  14. krmcg
    2,592
    2,393
    Whittier, CA
    (818) 512-xxxx
    #34 krmcg, Jul 22, 2016
  15. thunderstruck
    154
    151
    Port Charlotte, FL
    2022 Prius
    Please share it with all of us (the solution, not your phone number.) I didn't take mine apart as it's way too hot tonight but need to know before I start how the connector works if it's different.
  16. booke02
    booke02 Active Member
    391
    415
    Israel
    Are you showing the connector that was plugged onto the spade connector on your factory-installed horn?
    I changed my horn - there was a spade connector to the factory horn that I slipped off (after pressing the locking clip to release it) and simply reconnected to my new 74100. It didn't look like the your picture. (Sorry, I didn't take a photo of mine)
  17. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Has anyone installed a real Airhorn in thier Prius. I'm thinking like those YouTube "Hornblasters" fellas? I wonder if there is room to fit the compressor and horns, etc.
    Would work wonders creeping In EV mode up on the pricks txt'ing, driving like a holes, etc..... BBBRRRAAAAAAAAAA!!! Lol!!
  18. krmcg
    2,592
    2,393
    Whittier, CA
    That's the same as mine.
  19. jbkendrick
    232
    197
    Baltimore, MD
    Yes that's it. Are you saying that you were able to remove one of the spade connectors from the factory horn? J
  20. booke02
    391
    415
    Israel
    Yes, that is exactly what I did.
    The whole process was quite easy. The hardest part was undoing the nut holding the left hand horn
    krmcg likes this.
