Changing horn in 2016 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by booke02, Apr 16, 2016.
  1. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    Kendrick from your picture of old and new horn it appears that what you believe to be the old horn is actually the pedestrian "get out of the way!" speaker. no wonder you were confused. the actual old horn is mounted next to where you unmounted the pedestrian speaker.
    iPhone ?
    krmcg likes this.
  2. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    Th
    Thanks to everyone who helped me with the horns especially krmcg for his personal help. I got them installed today and sound much better. I added a little white lithium grease on the exposed metal spade connector in an effort to limit rusting. Was able to use the factory brackets and just plug them in to existing cables. Very nice. J
  3. krmcg
    2,592
    2,392
    Whittier, CA
    Good job
    jbkendrick likes this.
  4. Terre
    Terre New Member
    Easton
    Hello, I have a 2 wk new Prius (trim II). I want to replace the horns also, I like you comment for the 2016 Prius with the FIAMM 74100 El Grande horns! No modifications. Sounds great. Would that void any warranty? copy me the steps please
  5. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    I have replaced my peep peep horns with PIAA Automotive Superior Bass Horn 330/400Hz . Same as the Toyota factory upgrade, but they use the higher note. A bit lower note than the Sports Horns but straightish plug and play. Almost the same current draw as the originals but much louder. I would have fitted the FIAMM AM80's same as US Freeway blaster but the PIAA use 3.6 amps less current, so I played safe as I didn't have a wiring diagram and was not sure if there was a relay fitted. I note since that one is fitted so could have upped the game but these are pretty good. I used the extensions off the old horns with a bit of a forward bend.
    RCO and Mark57 like this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  7. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    #47 Philthunder, Jul 17, 2017
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
