Changing Hybrid Axle Fluid - 2012 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by brakeshoe87, Apr 6, 2017.
  1. brakeshoe87
    brakeshoe87 Junior Member
    My dealer recommended I change the :hybrid axle fluid" on my 2012 Prius with 65000 miles on it. I declined the service until I had a chance to research it. Problem is I can't find references to axle fluid. I see posts on transmission or transaxle fluid but I am not sure if these are the same. Can someone explain what this is, whether it is needed, and what a reasonable price is. Thanks
  2. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    They are one and the same and you should do a drain and refill (Don't pay extra for a "flush" as it is not useful on a Prius.). My dealer charges $100 for this service and since the materials cost almost $50, that is a reasonable price. Confirm that they will use Toyota type WS Transmission fluid as that is specified in the Prius manual.
    JeffD
    52,747
    it is not on toyota's maintenance list, because they consider it 'lifetime'. but if you are going to keep the car a long time, many people here recommend it.
    it's actually very unusual for a dealer to recommend it. most won't even do it, or are very reluctant when you ask them to.
  4. Mendel Leisk
    42,228
    Yeah, that was my first thought; maybe those guys are "keepers".
    Yes. And the letter-by-letter description in the Owner's Manual, is:
    GENUINE TOYOTA ATF WS
    If you're inclined to DIY, or are just curious what's involved, it'll require cracking 4 quarts (or liters) and will actually take around 3.5 quarts. They cost under $10 apiece, and the drain and fill bolt washers are maybe $2 apiece.
    Unlike a conventional automatic transmission, around 90% drains, so you are getting a near-complete fluid change with one drain and fill.
  5. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Toyota needs to get their story straight with these trans axle fluid changes.. they say its "life time fluid" so strange that they recommend draining it. Its a good idea to do don't get me wrong, but come on Toyota, its either recommended or its not..lol
  6. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Marketing pressure pushes the manufacturers to minimize the amount of periodic maintenance required as a sales feature. That is why Toyota says that the ATF is a "Lifetime fluid". If you read the manuals carefully, you will see a somewhat different schedule for "Harsh environments". My wife's Subaru dealer follows the "Harsh Environment" maintenance schedule for her Crosstrek saying that just the weather variation in Connecticut makes it a harsh environment for cars.
    JeffD
    Raytheeagle likes this.
  7. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    CVT fluid.
    I personally think you can let it ride way past 65k.
  8. Former Member 68813
    3,524
    983
    US
    The word is transaxle.
  9. Hjeff
    Hjeff Junior Member
    25
    It's easy. Valvoline's Maxlife is excellent. See youtube videos.
  10. Mendel Leisk
    42,228
    Why throw that out, considering the Owner's Manual strongly cautions against using anything but the specified Toyota fluid? I mean: fine, it's working for you, but don't evangelize, lol.
    See this:
    Pros and cons aside, why go contrary to a strong warning??
    #10 Mendel Leisk, Apr 10, 2017
    Prius_Angie likes this.
