Changing the Brake Pads
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vhmarx, Apr 28, 2006.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    We don't even know if this "fairly simple procedure" even works. It will clear the DTC. It can NOT command the solenoid valves or the boost pump
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I suggested that he try that procedure to clear the error status , no other reason.
  3. diggydimdum
    diggydimdum New Member
    San Francisco
    FYI for those wondering what "standard" brake pad thickness, according to the service manual:
    Front: Standard- 11mm, Minimum- 1mm
    Rear: Standard- 4mm, Minimum- 1mm
    Mine were just checked at 60k and I have 9mm in the front and 2mm in the rear. I'm not really sure how I lost 50% in the rear compared to 20% in the front.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ 2 mm wear front and back. Does even brake use seem so surprising ?
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yes, about 65%-70% of braking is done by the front wheels.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ Then how about a rounding error. 1.33 mm vs 2.66 mm.
  7. Mendel Leisk
    42,254
    Well, the rears are drum shoes, aren't they, on second gen? Maybe you're going through the rear shoes because of parking brake use. And the front are near pristine because of mainly regen braking occuring.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I think shop wear "measurements" are also often an eyeball estimate until the lining starts getting thin.
    On other disk/drum bake cars it's not unusual for the rear linings to outlast 2 or more sets of front pads, particularly if most braking is gentle.
